My Maytag Neptune MHW2000AWW will not lock? Is there anything I can do. I am very mechanically inclined. Last night it stopped spinning and when I checked the online manual today and then looked at the machine I realized it is not locking.
    Problem Solver:
  • 14 Answers
It is a sensor on the lock that tells it to lock its not working replace lock sensor . also check the circuit board in rear of washer.
Posted on Sep 08, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mhw2000aww does everything but full spin
You will need to replace the motor control on the unit. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 16, 2012 | Washing Machines
My mhw2000aww is no longer locking during wash cycles or properly spinning the closes when wash cycle is complete clothes are coming out saturated still is there a control board that i could replace to...
You most likely have a bad (lock wax motor) that can also cause the main control board to go bad. the lock motor sits above the washer door behind the panel. the control board sits inside the dryer above the drum to the right. go here to look up your parts
Mar 24, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag MHW2000AWW will fill with water but not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune front loading washer which stops at the spin cycle. I have tried turning it off and restarting from the beginning and also from the spin point. No luck. It is currently unplugged to...
try check the drain pump for any obstruction the may be stopping the flow of water or the impellar wheel itself. if there is nothing there then you may need to check the door lock mechanism or replace the main control board
Jun 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
Maytag mhw2000aww neptune front load will not spin dry ,door does not lock will go through entire wash with out spining dry
The timer is likely failed on this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Maytag Washing Machines
I HAVE AN OLDER MAYTAG NEPTUNE FRONT LOAD WASHER MOD# MAH3000AWA. I AM HAVING TROUBLE WITH IT, IT WILL NOT DO THE FINAL SPIN CYCLE IT SPINS WHEN IT WASHES, AND RINSE CYCLE, BUT THE FINAL CYCLE IT JUST...
Maytag Neptune defective door latch wax motor update
by: Anonymous
The older Neptunes, such as the 2000 Stackers, MAH3000, MAH4000 and the MAH5500A series had some issues which I am sure Maytag has corrected these issues in the newer machines...
There are thousands who have been burnt by the door latch wax motor failure. What happens is the machine will stop spinning because the door latch will fail to lock. Deep inside it is caused by the mechanism that locks the door. The wax motor will draw too much current and damage the control board by burning a resistor (R11) and a triac (Q6).
However, if Neptune owners know to replace the door latch wax motor they can prevent the control board failure from happening. Please tell everyone you know about this important fact.
The older Neptune’s also have a couple additional issues such as the moldy door boot and the reliability of the motor / motor control board. All three of these issues were involved in the class action lawsuit a couple of years ago. See http://www.neptunewaxmotor.com for more Neptune information.
Feb 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
