Question about HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050C stops printing - no error message
HP DesignJet 1050C stops while printing, display goes blank, all 5 lights stays on, no error message.
Switches off then on, continues for another 1 meter plot then stops again.
Any ideas?
    Scholar:
  • 96 Answers
Check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Posted on Sep 09, 2009
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Dec 29, 2010 | HP DesignJet 1050c InkJet Printer
The problem is even we already replace the printheads with the new ones, the plotter still shows error message : replace 20 status. is there any way to solve this uncommon problems ?
When false "replace print head" messages occur, it is almost always a bad trailing cable. They are a little tricky to replace but if you want the manual to see how to do it, download it here: www.lpscomputer.com/ec/manuals.htm
The part is available here: http://www.lpscomputer.com/p-2296-c6074-60418-designjet-1050c-1055cm-trailing-cable.aspx
Jan 05, 2010 | HP DesignJet 1050c InkJet Printer
SYSTEM ERROR CODE 04C300 C8CC0000 THEN STOPPED PRINTING MIDWAY THROUGH JOB iT SAYS TO HIT ENTER TO CONTINUE BUT GOES INTO A LOOP OF ERROR CODE /HIT ENTER, ETC
This is an IO error. Remove the back cover and disconnect the cables to the HDD and remove the JetDierct card. Print the internal test page. If it prints OK, install the Jet Direct card. Print again. Prints OK? Replace the HDD (or run without it). Does not print OK?
Replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Dec 16, 2009 | HP DesignJet 1050c plus InkJet Printer
HP Designjet 1050c begins to plot, then stops plotting with the error message "Turn of printer, check printhead path". What is the problem?
you need to lubricate the slide bar with some thin oil ( sewing machine oil).put the oil on your finger and then touch the bar this way you wont spil oil into the printer
Nov 03, 2009 | HP DesignJet 1050c InkJet Printer
DESIGNJET 755cm ERROR MESSAGE: TURN OFF PLOTTER CHECK PAPER PATH. THERE IS NO OBVIOUS BLOCKAGE TO PAPER PATH
If there is no obvious obstruction in the print head path, the most likely problem is a worn carriage belt. Open the front lid and check for rubber crumbs under the carriage belt. If there are crumbs, the belt is disintegrating and needs to be replaced.
The service manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm and the parts are available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Oct 10, 2009 | HP DesignJet 1050c InkJet Printer
Check printhead path error message
hi
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
Sep 10, 2009 | HP DesignJet 1050c plus InkJet Printer
1055cm plus locks up when printing... Display
did you check the trailing cables? check both ends (carriage and main pca)
Aug 05, 2009 | HP DesignJet 1050c plus InkJet Printer
System Error 0B000D 0000000D on display, nothing prints
Hello.
From the service manual:
System Error: 0B000D
Problem
Description:
24 V source test failure.
Corrective Action: Replace the Electronics Module
HP Part number: C6072-60146
I just looked up the pricing and it's not cheap. Let me know if I can be of further assistance.
May 28, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
592 people viewed this question
Seeker5211
Seeker5211
