Question about Whirlpool Calypso GVW9959K Top Load Washer
After washing a lite load of a shower curtian (made of material) and 2 wash cloths, I opend the lid of the washer and the shower curtian was missing, i think it is under the main part How would i get it out?
  • 867 Answers
This is inpossible to happen. nothing bigger than a small sock could dissapear
Posted on Sep 08, 2009
Why the fan is not working , the fan not move
1.Check to see if the washer is overloaded. Modern washing machines have automatic shut-off devices for out-of-balance loads. Try removing some of the clothes out of the washer and restart it. Check to make sure the lid closes properly and that the lid switch clicks when the lid is closed. If the lid switch does not click, then the switch may need to be replaced or the lid may be bent. If the washing machine still does not spin, go to Step 2. Make sure the water is draining properly. If the water does not drain out, then it could cause the washing machine not to spin. Check all the drain hoses for any clogs or kinks. This is easily done by disconnecting the drain hoses and doing a visual check for clogs or kinks
3.Check to see if any belts have came off or are loose. Unplug the washer and pull it away from the wall. Use the screwdrivers to remove the back panel. Visually check for any broken or loose belts. Replace any loose or broken belts.
4. While the back panel is off, visually check for any loose or missing bolts on the motor or drum. If any are missing or loose, tighten them and replace the ones that are missing.
5. If everything has checked out to this point, then the water level switch could be bad or the water level hose could be clogged. Remove the front panel of the washer and locate the clear tube going from the tub to the water level switch. If lint or debris has gotten into the water level hose, then the washer may not spin fast. Clean the debris from the hose by blowing on the hose or tapping it on the side. To check the water level switch, go to the back of the washer and locate the back end of the water level hose. Use the voltmeter to check to see if the water level switch is getting any power.
6.If the washing machine still doesn't spin fast enough or doesn't spin at all, then it is time to call in a professional washing machine repairman.
  • 1
    Checkto see if the washer is overloaded. Modern washing machines haveautomatic shut-off devices for out-of-balance loads. Try removing someof the clothes out of the washer and restart it. Check to make sure thelid closes properly and that the lid switch clicks when the lid isclosed. If the lid switch does not click, then the switch may need tobe replaced or the lid may be bent. If the washing machine still doesnot spin, go to Step 2.
  • 2
    Makesure the water is draining properly. If the water does not drain out,then it could cause the washing machine not to spin. Check all thedrain hoses for any clogs or kinks. This is easily done bydisconnecting the drain hoses and doing a visual check for clogs orkinks
  • 3
    Checkto see if any belts have came off or are loose. Unplug the washer andpull it away from the wall. Use the screwdrivers to remove the backpanel. Visually check for any broken or loose belts. Replace any looseor broken belts.
  • 4
    Whilethe back panel is off, visually check for any loose or missing bolts onthe motor or drum. If any are missing or loose, tighten them andreplace the ones that are missing.
  • 5
    Ifeverything has checked out to this point, then the water level switchcould be bad or the water level hose could be clogged. Remove the frontpanel of the washer and locate the clear tube going from the tub to thewater level switch. If lint or debris has gotten into the water levelhose, then the washer may not spin fast. Clean the debris from the hoseby blowing on the hose or tapping it on the side. To check the waterlevel switch, go to the back of the washer and locate the back end ofthe water level hose. Use the voltmeter to check to see if the waterlevel switch is getting any power.
  • 6
    Ifthe washing machine still doesn't spin fast enough or doesn't spin atall, then it is time to call in a professional washing machinerepairman.
  • Read more: How to Repair a Washing Machine That is Not Spinning Fast Enough ' eHow.com http://www.ehow.com/how_5025687_repair-not-spinning-fast-enough.html#ixzz1CKKbvlyA
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
    Jan 28, 2011 | Magic Chef CAV2000 Top Load Washer
    Washing curtians
    Select a delicate or wool programme, this will give you a cool wash and a slow spin.
    Feb 03, 2010 | Zanussi F1045W Front Load Washer
    Rusting lid on top-loading Kenmore Washing Machine
    that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
    Jan 23, 2010 | Kenmore 24032\24036 Top Load Washer
    I have an older front loading washer Frigidaire and it's now smelling like mold on all our clothes thought it was me leaving clothes in to long but it's not. model #FWT445GES2 serial #XC74463636 . I have...
    No recall, Pour 2 cups of bleach into the washer, Wash on HOT water, long cycle. Then wipe seal with dry cloth. This will eliminate the mold smell... To stop it from coming back ALL front load washer doors MUST be left open to allow the rubber seal to dry, Just like you close your shower curtain so it doesn't get musty smelling... 2 hours is about the dry time... wiping the seal with a cloth usually helps too... All located in your owners manual/
    Jul 31, 2009 | Washing Machines
    Smeared clothes
    Hi!
    You can look at this as to how lint/whitening from your clothes can be removed---
    This is due to un-dissolved soap and is worst in a colder climate where the cold water entering the washer is much colder than normal.
    Cutting usage to 1/2 of what it says will still wash good and also cut your chances of getting "whiting" on your clothes.
    Over loading the washer is another cause: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
    Water temp is also important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F.
    Feb 09, 2009 | Roper RAX4233PQ Top Load Washer
    GE Top Load Washing Machine -- Agitator will not cycle
    Agitator's don't spin on wash cycle.
    I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
    Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
    Jan 26, 2009 | GE WBSR3140DW Top Load Washer
    How much clorox 2 and fabric softener
    DONT USE CLOROXE 2 ITS NO GOOD make sure you wash on cold / cold that makes the colr last and no shrinkingit takes a full lid on full load half lid on medium and 1/4 on small load same with scoops
    Feb 06, 2008 | Malber WD1000 Front Load Washer/Dryer
    Washer stopped
    Sounds like might be the lid switch... these washers are  well know for lid switch problems,
    Sep 21, 2007 | Maytag Atlantis MAV6451 Top Load Washer
    Whirlpool Calypso GVW9959K Top Load Washer Logo
    26 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
