Question about Kenmore Refrigerators
Frige will only cool now and then clicking sound coming from temp control
  • 93 Answers
Are you sure the sound is coming from the thermostat or temp control as you call it? A lot of times the clicking noise is the start relay on the compressor....which is not sarting the compressor. Sounds like your start relay but I'm not there looking at it. I changed two start relays in 2 days this week. It is common.
Posted on Sep 13, 2009
My refrigerator/freezer is warm
If the motor is running but it's not getting cold then you may have lost coolant. Did someone clean the ice out with a knife?
Apr 28, 2017 | GE Profile PSW26P Stainless Steel Side by...
I have a amanda 1bb1924dew bottom freezer frige. The compressor is running and cools the freeezer to normal temps but the frige area is about 60 degrees. I set the frige control on high and it still does...
12002355 Thermistor
Are you sure that the model is not ABB1924DEW? I want you to test the=> 67003903 Damper Control Assembly Here is a ABB1924DEW Service Manual and you will need to place refrigerator into self diagnostics. The problem is either a defective 12002355 Thermistor or a defective 67003903 Damper Control Assembly Here is another source for the 67003903 Damper Control. Here is a ABB1924DEW Parts List and a ABB1924DEW User Manual You are going to have questions so please ask, Thanks Sea Breeze
Feb 01, 2013 | Refrigerators
The temp alarm is sounding
Auto defrost system not working properly
staying in defrost to long,door gasket leak
compressor overheat,controls turned up max
all above can cause your problem
even cloged defrost drain
Apr 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
I have a Dometic RV frige that freezes everything in the frige section even when i have it set on the lowest temp setting
thanks for the question sounds like a defective cold control replace it thanks the appliance doc
Sep 16, 2008 | Refrigerators
Refrigerator side not working
The freezer is workig fine but refrigerator side is not cooling.
Jun 10, 2008 | Whirlpool GS6NBEXR Side by Side...
Not cooling
listen for the sound of a hum and a click in back of the refrigerator. If you hear the sounds your compressor has failed.
Jun 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Oct 25, 2007 | Refrigerators
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
