Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The timer works and fills with water. the belt is
The timer works and winds down and fills with water. the belt is not broken, the washer will not cycle through.
    Sergeant:
  • 228 Answers
The motor brushes have worn out will need replacements
Posted on Nov 10, 2009
  • 574 Answers
So you start the easher it fills with water but does nothing else is that correct? If so It is possible that your door switch is faulty
Posted on Sep 08, 2009
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
My Frigidaire front loader washer drum will not turn or agitate but will fill water and drain water, what is the problem?
Hello acoach194 - If the washer is not agitating try the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this. If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, then it will need to be replaced. If it is loose, then it will need to be tightened. A professional will need to do so by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, once again call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Dec 17, 2012 | Frigidaire FTF530FS Front Load Washer
Washer fills and agitates but wil not empty or spin. I tried to bypass the lid switch and still same problem. How do I check the timer.
Hello there and thank you for choosing fixya
OK first lets get back to the basics
First investigate these things fully
It doesn't drain dot_lineone.gif 1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. TIMER OR CYCLE SELECTOR
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. THERE IS NO REPAIR FOR THE TIMER
Aug 04, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Have Whirlpool washer Mod LSQ9264HQ0 fills with water and stops. Won't go forward will add more water but nothing else works. Have checked for broken belts, no belts. Has power in ,door switch has...
If there is no noise coming from the motor (would indicate a bad coupling - your machine is direct coupling drive - no belts)
Then your timer has failed.
CLICK HERE to see the part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 23, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will agitate but does nothing through it's spin cycles. The timer advances through the spin cycle but you can't hear the motor run or even try to start, Washer is aout eight years old.
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
as you mentioned timer advances,then check out cold water entering the machine or not. If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jul 13, 2009 | Maytag Washing Machines
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
As washer was on final spin cycle it sounded like a belt came....
Apr 01, 2009 | Kenmore Washing Machines
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
Jan 24, 2007 | Maytag Performa PAV2200
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
229 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
