Question about Motorola Mobility RAZR V3x Cellular Phone
Set up configuration
I have problems with the set up configuration. Cd starts normaly after rebooting the computer the set up configuration blocks and doesnt finalise the set up
  • Leo Mulder Dec 10, 2007
    I am running windows xp. dont where to look for msconfig.
    can you be more specific?
Try running msconfig and look for restart after reboot or something similar and uncheck it.
Posted on Dec 09, 2007
  • boozebee Dec 10, 2007
    ps, click on the startup tab aftering opening msconfig.
Sony vaio e series laptop model pcg-71211w is showing some hard disc problem and not starting normaly. It starts after pressing F1....
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 20, 2013 | Computers & Internet
I bought a used ibm r40, changed the hard dsrive and tryed to load xp pro. after loading the system files the computer wants to reboot to finalise. After this it goes right back to fresh install start.
When you say you tried to load XP Pro, did the hard drive already have XP installed or are you installing it fresh from a CD? If you are installing it fresh from the CD and it is asking you to reboot, it seems as if you are letting it try to boot again from the CD. When it reboots and says "Press any key to boot from CD..." don't press anything, just let it boot. It should finalize the installation there!
Hope that helps!
May 23, 2011 | IBM ThinkPad R40 2722 Notebook
My sony crx320ee cd-rw/dvd stop functioning normaly, cannot burn cd now. plz hlp!
i would recommend uninstalling the drivers completely and reinstalling them, however most drivers for cd roms cd/rw are preinstalled, and the only thing you can update is the firmware for the device itself. you may want to try unhooking the drive and rebooting the computer, then turning off the machine again, and reattach the drive, and restart. that might force it to re-configure and re-load the drivers
Dec 29, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
How do you Reboot a computer back to factory setting
Instructions Things You'll Need:
  • Factory Settings CD
    How To Use the Restore Factory Setting CD
  1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
  2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
  3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
  4. Step 4 Reboot the computer to complete the process.
  5. How to Reboot Using the Computer Start-Up
  6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
  8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
Jan 27, 2010 | Computers & Internet
After installing Vista SP2. computer tries to reboot, but cant configure update 3of 3, so it reboots to start all over. tried setting CD as 1st boot, hangs waitng for CD-rom then boots off HDD. Tried...
ok go into your bios and load default settings.
set your cd-rm as your first boot device. then HDD.
save settings and exit. allow unit to reboot.
you can contact me direct e-mail.
so i can give you one on one technical support.
Nov 14, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Cannot start windows normaly,in safe mode,whit commad prompt. Even last know good configuration doesn't work!! what can i do? pleeeease! alfie
The first thing to do is reboot your computer with the windows xp installation cd.
After that select the REPAIR option.
This will open a command prompt windows D.O.S. type.
Execute the following command:
chkdsk c: /r
It will take a while to finish.
When it is done, type EXIT to reboot your computer.
If this doesn't work your probably will have to reformat your computer and star over.
Jan 18, 2009 | Computers & Internet
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
System Service Exception Error (Blue Screen) - Acer AX1200
If you can reboot to Safe Mode and select "Last Known Good Configuration" it will be best but if you can't then you have to completely shut- down and reboot with your Restore or Windows CD and select the options to do a "Repair"
Jan 02, 2009 | Acer Aspire 3680 Laptop
My computer will not reboot
this will either relate to a hard disk fault or a corrupt driver or registry file, if you cannot get into safe mode, or last known good configuration, you may have to run a windows repair using your XP cd
Sep 14, 2008 | Microsoft Windows Vista Ultimate Edition
Rebooting problems fujitsu siemens
I WAS GIVEN Gateway model: FMN 400C I WANT TO MAKE IT WIRELESS ? IS THIS POSSIBLE ? HOW AND WHAT WOULD I NEED TO DO ? I HAVE BOUGHT AND INSTALL A NEW WIRELESS CARD..STILL HAVING TROUBLES WITH MAKING CONNECTION TO THE MODEM.I was on the phone with cable people.Yes I have wireless set up already.Where can i find instruction Manual? I can get green light on the card sometimes.Socket for cable either net wire be loose?
Mar 24, 2008 | Computers & Internet
Motorola Mobility RAZR V3x Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
