Question about HP Compaq FS7600 17" CRT Monitor
Blank Screen my monitor is on and i can hear the functions of my yim getting im's but my screen is blank. i have turned it on and off but it still just has a blank screen
    Sniper:
  • 58 Answers
Check the siignal cable connection to the CPU from the monitor
Posted on Sep 08, 2009
If i select source to pc display will become blank and power indicator blinking.
• You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is a blank screen displayed and does the power LED blink at
a 1 second interval?
1. This occurs when the power saving function is running.
If you click the mouse or press any key, the screen will be
turned on.
2. This occurs when two monitors are connected,
is and Magictune is running. In this
case, characters on the Magictune OSD may appear
corrupted. To run the Magictune, the must
be set to . Please restart your PC, set the
to and run the Magictune.
Jul 07, 2011 | Samsung BX2231 21 inch Monitor
My hp pavillion tx 2000 laptop is not working.............. when i turn it on, all the relevant lights comes on but nothing appears on the screen. i only get a blank screen.................. what could...
If you hear it start up and the lights come on, try hooking up an external monitor. When you do, be sure to push the Fn key plus whatever special function key shows 2 monitors on it so the output will be directed to the external monitor.
Sounds like the LCD screen might not be working.
Apr 20, 2011 | Computers & Internet
When i turn on the laptop it shows blank screen only.how can i fix it. thanks
Do you see anything at all such as the boot up logo? can you hear the HDD spining? if you can hear the HDD spining but you see nouthing try the following.
connect an external monitor. Look along the function keys and find one with a screen logo on it press fn and the appropriate F key and it will switch to the external monitor. The switching of screens is normally 3 cycles 1. external monitor on 2. both laptop screen and external monitor on 3. back to laptop screen.
If the external monitor comes on it's the screen inverter or screen at fault.
Once you have confirmed what the problem is we can move on to checking the screen wiring or a screen or inverter change.
Aug 18, 2010 | Computers & Internet
Monitor is blank when we turn the computer on.
Maybe not. Find the FN key. It is usually BLUE in color
Then look on TOP row of Computer keyb (or all over) and find CRT/LCD.
Press the FN and that key and your screen should come back. You accidentally sw. it to CRT (outside, external monitor)
Jan 14, 2009 | IBM ThinkPad T23 2647 Notebook
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Blank screen
your pc no good call your comper sellwer
Apr 01, 2008 | HP Compaq nc4010 Notebook
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
Blank Screen
ccfl ( cold cathode flouroscent lamp ) is the backlit feature of the lcd panel. If you see a blank screen but do see the output on the external monitor then you sure have to take it to the hardware tech to get the inbuilt LCD panel checked. it seems to be a electronic failure. Thanks Ashish.
Sep 21, 2007 | IBM 11P836402 for ThinkPad R40 Monitor
HP Compaq FS7600 17" CRT Monitor Logo
239 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
