Question about D-Link DI 514 Wireless Router (DI-514)
Router not detected
The linksys chat person said i should upgrade but the web address they gave me did not give me the login screen they said i should get. Anyway everytime i try to set up my wireless router it says not detected but the router is on and all the lights
  • 205 Answers
Usually you set up a wireless router by first plugging in an ethernet cable so you can adjust all the settings. Have you done that?
What ethernet address did they give you? Something like 192.168.1.1?
Let me know.
Posted on Dec 09, 2007
How do i log in for the first time
Basic step for login Linksys Router :
  • remove the router and modem power plug.
  • connect your router with modem.
  • power up router and modem.
  • open the Web Browser - 192.168.1.1
  • username- admin or blank and password- admin.
that's all for login
if looking for more help http://support.linksys.com/en-apac/support/linksys and Router Support for setting up your router setting.
May 19, 2014 | Computers & Internet
Want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
I cant login to my routers thing
If you have forgotten your login password:
Perform a Linksys reset
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 24, 2011 | Linksys WRT120N Router
I have tried connecting Cisco linksys router but it gives ERROR 322 NEW ROUTER OR GATEWAY NOT DETECTED...How can I solve this problem please advice
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see output like:
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
if the router has self-configured, and is ready for "wired" usage.
Then, start Internet Explorer.
Type http://192.168.1.1
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure it for "wireless" usage.
Feb 21, 2011 | Cisco Linksys Wireless N Home Router...
I have a LINKSYS WAG54G2 gateway but no internet connection.
Login to the web-server "inside" the router, and verify that the 'WAN' side of the router has obtained an IP-address from your Internet Service Provider.
Aug 01, 2010 | Linksys WAG54G-UK Router
2wire 2700HGV cannot detect wireless Linksys IP camera WVC54GC
Purchase a different router and return the 2wire to the ISP explaining it is not compatible with your equipment at home. You may need to provide them with the new router's MAC address.
Nov 21, 2008 | 2wire 2700HG-B Router (2700HGB)
Used router, so the wireless is already setup with a newtork password. is there a way to reset the network password or setup? the friend who gave me the router is no longer in the country, and so I cannot...
Most LinkSys Routers do have a master reset. It is a small recessed button normally at the rear of the unit between one of the antennas and the WAN/Internet port. For a full reset, you need to press this for more than 10 seconds. Of course doing a full hard reset reverts the unit back to factory default.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 29, 2008 | Linksys Wireless-G WRT54G Router
Firmware
Here's the Linksys step-by-step guide for your router:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3686&lid=5531661879B01
Are you connected to the wireless router with an ethernet cable? Generally, you want to hook it up this way first so you can configure it. If you are hooked up with a cable open your web browser and type in the following address: 192.168.1.1 this should get you to the router's web page. The default login for linksys is username: blank, password: admin
See if you can connect to the router in this way. If you can then we can go through the next steps or you can try using the above link.
Good luck.
Dec 19, 2007 | Linksys Wireless-G WRT54GS Router...
How to Upgrade the Firmware on a Linksys Router
I have update the fireware of linksys router WRT54G ver.2.2 by wireless.. Wrong move.. Then it stop loading.. now I can not get in to the router even i reset the router.. what can i do to have it back..
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Charter High-Speed Cable and the BEFW11S4 Version 4
To resolve this problem, you will need to upgrade your router's firmware. Click ftp://ftp.linksys.com/pub/network/befw11s4_v4_v1.50.14_code.bin and download the file to your Desktop or My Documents folder (the link is to v1.50.14 firmware code). Once the BIN file has been downloaded, follow these instructions to upgrade the router's firmware: NOTE: Before upgrading your router's firmware, please make sure that the procedure is being performed by a computer that is connected directly to the Router with an Ethernet cable and not a wirelessly connected computer. Accessing the Router's Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Upgrading the Router From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. Click on the Administration tab. 2. When the ?Administration? page loads, click on the Firmware Upgrade sub-tab. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. If the logo matches the image above ("Linksys"), follow these steps: 1. Click on the Help tab. 2. When the "Help" page loads, click on the Upgrade Firmware link. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. After completing the steps above, the router's firmware should be upgraded successfully.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
D-Link DI 514 Wireless Router (DI-514) Logo
26 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
