FILM DOES NOT REENROLL
I played in parameters to solve a problem. Now, the film does not reenroll. What is wrong ?? Thank's for helping
After the wash cycle is complete, it leaves a visible film on some surfaces (semi-gloss). Only a hand scrubber will remove this. It's an older model: AAU30000 Thank you.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | Admiral Dishwashers
I recently put film into my camera and it was all loaded up and working but today when i turned it on, it made this weird sound and then the film count went back to 0 and the word that said film was...
Try changing the film,I own a Pentax and experienced the same problem.I threw away the previous film and loaded it with a new one,it worked fine.
Thank You.
Feb 22, 2011 | Minolta Maxxum 7000 35mm SLR Camera
My dishwasher is leaving soap residue on the dishes. What do you think is wrong?
heatman101
-=00=-0=-
Oct 22, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
Making noise and leaving white film on dishes
the white film is due to hard water. go to www.dishwasherfilter.com and get the new difi filter. it will solve your problem imediately and extend the life of your dishwasher. the product is amazing and guaranteed to work. very affordable
Mar 29, 2010 | GE Nautilus 24" Built-in Dishwasher
Have Whirlpool dishwasher #GU2300xtsqo. White
heatman101
Feb 16, 2010 | Whirlpool GU2300XTS 24 in Builtin...
Nothing shows up on the film!
The Ilford Delta 400 Professional is indeed DX coded. Since the camera does not allow you to check the shutter without film inside, there's no way we can confirm the shutter is working properly. So only option is a service center. Since all other things are working properly, it should be a simple repair.
Feb 11, 2009 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Maxxum camera no color
I think your camera had a microchip in it that changes modes. I could be wrong, I can't remember exactly what model it was. Take the chip out or reset it in the menu. How old is the film you are using? There is some film that is color film but a black and white emulsion. That can be developed in color processing.
Jan 04, 2009 | Minolta Maxxum 300si 35mm SLR Camera
Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Mar 15, 2008 | Office Equipment & Supplies
Scanner not working
hrm, i found out how to solve the issue. remove the film and do a calibration for the frame, now the scanner starts to calibrate, after a 30sec the program told me to put the film in and scan.
tadaaaaa..
Jan 13, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
13 people viewed this question
k24674
