Question about Traeger Industries BBQ070 All-in-One Grill / Smoker
I have a Little Tex approximately 6 years old .About 4 years ago I put in a Residential Thermostat with multi level controler.Worked great until yesterday. Started at 450 ,10 or so min. later it was at 250 with no visible smoke.I turned it to smoke----after 20 min still no visible smoke and it remained @ 250. I changed out controler with an old 3 level my Son had ---same results![the 250 measured by hood therm.]Suprisingly the pork chops ultimaely turned out great ,just without any good smoke flavor.
  • robertpyzel Sep 08, 2009
    Apparently it was not clear to previous expert that I had already tried a second controler with no improvement.
  • 10,865 Answers
I recommend that you contact the company, traeger industries directly by phone at 877-Tex-Grill.
I believe that you will have to replace the thermostat with another designed especially for your little tex.
good luck with it. nothing like real BBQ.
Posted on Sep 09, 2009
    President:
  • 1,714 Answers
This sounds like the controller is not functioning correctly. Check to see that the sensor is placed correctly and that it is clean and free of grease. If that does not solve it, then the thermostat/controller needs to be replaced.
Posted on Sep 08, 2009
Thermostat sometimes doesn't turn furnace on
Hello Kathy, The first thing that I would do is change the batteries in the thermostat. One or more may be weak and not turn on your furnace. I would put in Alkaline batteries. If that doesn't help, maybe a new thermostat is in order.
Feb 27, 2014 | Hunter 44550 Programmable Thermostat -...
How do i replace the water thmostat 99 6 cylider
WELL YOU NEED TO DRAIN COOLANT LEVEL BELOW THERMOSTAT LEVEL.YOU HAVE TO DISCONNECT MAF SENSOR LOOSEN AIRDUCT 2 LARGE CLAMPS LOOSEN REMOVE 4 SCREWS TO AIR FILTER COVER LIFT UP REMOVE COVER. THEN REMOVE AIR FILTER AND HOUSING, FIRST DISCONNECT MAF SENSOR.YOU HAVE TO DISCONNECT THROTTLE CABLE AND SHIFT CABLE.YOU HAVE TO DISCONNECT REMOVE THROTTLE BODY COOLANT HOSES DISCONNECT IDLE SPEED CONTROL VALVE CONNECTOR AND DISCONNECT TPS SENSOR CONNECTOR. THEN REMOVE THROTTLE BODY ASSEMBLY. YOU NEED TO BUY NEW THROTTLE BODY COOLANT HOSES AND NEW THROTTLE BODY GASKET FOLLOW TOP COOLANT HOSE TO ENGINE BLOCK.NOW YOU SEE CAN AND REMOVE THE THERMOSTAT HOUSING REPLACE THE THERMOSTAT.BESURE TO HAVE EXTRA COOLANT ON HAND.BLEED COOLANT SYSTEM WHEN DONE.TO BLEED COOLANT SYSTEM REMOVE RADIATOR CAP ON OVERFLOW JUG.THEN OPEN BLEED SCREW ON THE WATER PUMP BYPASS HOSE PIPE JUST A LITTLE.POUR COOLANT IN THE OVERFLOW JUG UNTIL LEVEL STOP DROPPING.STOP AT COLD MARK ON JUG.CLOSE BLEEDER SCREW ON WATER PUMP BYPASS HOSE PIPE.CRANK VECHICLE CHECK FOR LEAKS. START UP ENGINE LET IDLE FEW MINUTES THEN CHECK COOLANT LEVEL ADD MORE UNTIL UNTIL LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON OVERFLOW RESERVOIR. LET ENGINE IDLE WATCH COOLANT TEMPERATURE GAUGE.WHEN GAUGE START CLIMBING. TURN OFF ENGINE WAIT FEW MINUTES TAKE A LARGE RAG OPEN RADIATOR JUST A LITTLE YOU HEAR HISS NOISE.WHEN PRESSURE STABILIZE DONT GET SCALDED BECAREFUL.OPEN CAP LITTLE MORE.IF COOLANT PRESSURE STILL BOILS OUT WAIT 20 MINUTES ADD MORE COOLANT TO RADIATOR OVER FLOW WHEN COOLANT LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON START VECHICLE UP LET IDLE UNTIL THERMOSTAT OPEN. THEN FEEL TOP RADIATOR HOSE FEELS HOT THERMOSTAT OPEN WATCH TEMPERATURE GAUGE.IF GAUGE TEMP START CLIMBING TURN OFF ENGINE WAIT A WHILE.CHECK AND ADD MORE COOLANT.WHEN THE ENGINE CAN IDLE TEMP GAUGE STOP CLIMBING YOU HAVE BLEED COOLANT SYSTEM.KEEP CHECK ON COOLANT LEVEL.
Dec 29, 2010 | 1999 Oldsmobile Alero
I have a Paloma PTG-74PVN tankless natural gas water heater. It was installed 3 years ago and has worked great until 2 days ago. Currently, the water heater will run for approximately 10 minutes, i.e....
Try turning the thermostat uo a small amount and see if this makes a difference. I suspect the control board is bad but I would try adjusting t-stat before I spent money on board or service call. Thank you
Dec 16, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Installed the new solar charger in July. ZThe hot wires and ground wires are properly connected, snd the fence is properly grounded. It worked great until approximately two week s ago (end of Sept). The...
I have see this happen before and its usually do to most moisture/rain getting in. ie use multi meter to varify solar charger putting out current/voltage. Odds are its not anymore. Rechargable batteries are notorius for not lasting but not in 2 months.
Oct 07, 2010 | Parmak Solar Fence Charger
Very little heat worked great 2 days ago
make sure you have the right thermostat in it usuall 160 degrees or so
Jan 03, 2010 | 1994 Jeep Grand Cherokee
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
How to vary the Multi zone levels at the receiver
Try putting amp to zone 2 go to set up menu for "variable" volume adjust and turn down the volume with the remote control volume buttons or use the volume control on the amp,this should work,i had the same problem with a YAMAHA amp and this worked.
hope this helps.
CABLE GUY.
Jul 16, 2008 | Denon AVR-3802 Receiver
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Traeger Industries BBQ070 All-in-One Grill / Smoker Logo
181 people viewed this question
Top Traeger Industries Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
