Bosch Nexxt  100 Series WFMC1001UC Front Load Washer
Problem for Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Bosch washer WFMC2201UC/15 has E13 error and will not fill
By hartselectri on Sep 08, 2009
fill valve screens are clean, no water left in tub from previous load
Solution #1
posted on Oct 21, 2009
Not Rated)
gurus_view
Rank: Wiz
Rating: 91%, 14 votes
Hi  hartselectri,
Check the drain hoses and pump That code is for a longer than normal drain if it did not drain it would not let you open the door, You need to clean the filter. Remove the circular panel on the front right put a little screw driver in the hole and twist the access panel will pop off. Then you will need to twist the handle of the filter and pull it out you will find what is stopping the unit from draining in there very common. Also have a lot of towels handy all the water in the unit will come out when you pull the filter.
Regards
R.K.
Was this helpful?
Yes
No
Popular Solutions for Bosch Nexxt 100 Series
Questions and Unsolved Problems for Bosch Nexxt 100 Series
Do you recommend Bosch Nexxt 100 Series WFMC1001UC Front Load Washer?
Answer
Answer
I have a bosch washer about 3 years old. It suddenly stopped on spin cycle and water would not drain... (More)
Answer
will not spin ,therefore you also can not open the door
Answer
Just an ordinary day doing laundry. I put in a load and dialed to the setting I usually do and it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
