Question about T-Mobile Sidekick ID Cellular Phone
Just bought a new sidekick id and web wont work.
Just bought a new sidekick id off ebay and i have a prepaid t-mobile accont. On my accont i have the web and it worked with my old phone but when i try to go on the web with the sidekick it says service unavalible. Is there a way to make the web work?
How do i get an unlock code for a t-mobile
your a looser hahhahahahha a get a new one like lx or somrthing
Jul 01, 2010 | T-Mobile Sidekick ID Cellular Phone
Cant get my sidekick to activate
Let me start by saying I'm not an expert, but after going through a lot of gyrations I came up with a solution that worked for me. I'm sharing it here because I haven't seen a complete concise answer anywhere.
The activation problem with Sidekick Slides is common. Most of the time, people buy a Slide without realizing that you have to purchase a "sidekick plan" from T-Mobile to get it fully activated. These phones were build especially for T-Mobile, so they're designed so that you have to have a Sidekick rate plan first to get the phone activated. By the way, this applies to a new phone as well as a phone that's been activated before, but has been 'hard reset" (where you hold the R button while re-booting.. My advice, DON'T DO THIS! Because you have to re-activate the phone.
However, there's good news for all you non-T-mobile folks who bought a Slide on eBay (or from a friend etc.) only to find it needs activation. Here's the solution. If you search eBay for "sidekick activation" you can find folks selling prepaid activation kits for around $15. They include a sim card and about $10 worth of sidekick prepaid services. Buy the kit, install the sim, and go online to register your phone (registering by phone is a pain with T-Mobile). Online you have 3 plan choices: Pay By The Day, Pay As You Go, and Sidekick. Pick Sidekick, and then provide the requested registration information. When done, your phone should be ready to go and should activate within about 5 - 10 minutes. You'll be charged $1 a day and airtime for calls, so it's not cheap, but at least the phone won't go to the activation screen when you startup.
The next question is, how to unlock the phone for other networks? IF it's not unlocked you will be prompted for special code (this is different than the user-defined password that simply locks the phone against unauthorized users). It won't work on other networks until it's truly unlocked. Again, the trusty folks at eBay can help. I searched for Sidekick Slide Unlock Codes and found numerous vendors, ranging from $6 to $12, who provide permanent unlock codes for Slides. I found on that provides the code via email (others want to mail it to you) and got my code within 30 minutes. So now I can remove the T-mobile sim and put my ATT (or other) sim in and go. I should mention that some of the Sidekick features ONLY work if you have a sidekick plan, but that's T-Mobile's and Danger's devious attempt to make us miserable. Good Luck! Hope this helps! Rick
Sep 13, 2009 | T-Mobile Sidekick ID Cellular Phone
Sidekick id charger light comes on but phone wont the screen wont turn on but charger light is on
Sounds like you unit is not charging. The Sidekick ID's are notorious forthat. If you have a friend that has a sidekick ID or Sidekick 3, see ifyou can try their battery to make sure you phone is working ok.
If so, your best option is to get an external charger that has a sparebattery slot That way you can charge the battery outside the phone!They run about 25-30 dollars on ebay. an extra battery is a good idea so you can have one charger at all times.
Sidekick ID and Sidekick 3 External Battery Charger
Jun 29, 2009 | T-Mobile Sidekick ID Cellular Phone
My mom will only let me get a pay as you go (prepaid) phone
yes i have a prepaid sidekick id, and sidekick 3
if you go on the tmobile website or bestbuy website they show the sidekick on the prepaid service list.
Dec 12, 2008 | T-Mobile SideKick Pay-As-You-Go Cell Phone...
My sidekick wont turn on
corbolicous1-
Is it a sidekick ID? If you bought if from t-mobile and it hasn't got wet or been dropped then call T-mobile CC. IT should still be under warranty. Do you have a friend that has a sidekick 3 or a sidekick ID that you can try the battery from(they are the same) What type of charging cradle, one witht the spare battery charging slot? Let me know....
Jul 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Unlocking Sidekick ID purchased from ebay
try turning it on and typing 1234 it should work it worked for me and if that doesnt work try goin to a cell phone repair shop they should be able to unlock it. if not get your money back for the phone and buy one at the tmobile store. some stuff on ebay doesnt work i bought an ipod off ebay and it broke the next day it broke so try gettin your money back if nutin else works!
Jul 22, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick id
YOu need to register the phone with t-mobile and sign up for a sidekick unlinited data plan. You can do it prepaid which is a dollar for everyday that you use it or 29.99 a month on a contract.
Apr 12, 2008 | T-Mobile Sidekick ID Cellular Phone
Sounds like you unit is not charging. The Sidekicks are notorious for that. If you have a friend that has a sidekick ID or Sidekick 3, see if you can try their battery to make sure you phone is working.
If not, your best option is to get an external charger that has a spare battery slot That way you can charge the battery outside the phone! They run about 25-30 dollars on ebay and since you have an extra battery you can have one charging all of the time!
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone will not turn on
Sounds like your charger port is busted. Ti is a common problem on sidekick 3 and can effect sidekick IDs as well. A fairly cheap workaround is to get an external battery charger. It will have a slot to charge the sidekick battery external formthe phone. They sell on ebay fior about 25 dollars.
The sidekick ID and sidkeick 3 batteries are the same so it will work. Check then out here
Sidekick ID battery charger
Feb 24, 2008 | T-Mobile Sidekick ID Cellular Phone
T-Mobile Sidekick ID Cellular Phone Logo
69 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
