Tv shuts off after about 20-30 min. stayed on all night with a fan blowing into the back with the rear panel off.
  • 556 Answers
Is there a message on the screen before the set shuts off, I'm guessing there is or you wouldn't have a fan blowing into the back of it. Is this a Mitsubishi? If it is call Mitsubishi and they will find a tech to come replace the defective thermal sensor free of charge.
Posted on Sep 11, 2009
2007 Panasonic 50in Plasma shuts off after being on 30 min sleep timer off, is the problem the cooling fans out/ over heating
Yes, cooling fan could be a problem. Just see whether it goes off during before shut off. If yes, the TV might need service. To know whether the fan goes off first or the TV, stick one side of any thin vibrating membrane such as a silver paper (like the one you see in cigarette packets) on the fan outlet, without blocking it, so that you can see whether it stops before the TV shuts down. Alternatively you can hand an inflated balloon which keeps flying off from the area of the fan and shall stop when the fan stops. I suggest this, in order to save your time looking at the rear all the time until the TV stops. Even then, one is likely to overlook whether the fan stops or TV stops first.
Aug 29, 2012 | Panasonic Televison & Video
My Toshiba powers off every few mins and will not turn back on until i unplug the tv and plug it back in. Will only stay on for another few mins. The long its unplugged the longer it will stay on up to ten...
It sounds like you have a bad capacitor. When one is faulty, they will demonstrate this type of behavior. The issue is finding out which one. If you are not a skilled technician, this is a difficult task. I would recommend that you take it to a TV repair shop, and let them repair it, if you are unable to. The good thing is that the cost of a repair is significantly less expensive than a new TV.
Mar 22, 2011 | Televison & Video
Phillips 50P8341 will stay on about 15 mins then shuts off then the power button flashes twice, pauses then flashes twice again...
Seems like it is overheating. Try cooling it down by using a fan to blow air into it (temporary fix). Make sure the TV is well ventilated and heat can escape (permanent solution).
Jan 15, 2011 | Philips 50P8341 50" Rear Projection...
Rca projection tv wont stay on but about 1 min then powers off and wont turn back on for about ten minutes then shuts off again after a min or so
Possibility Fan Cooler Issue Check at the back if your hear the fan going if not your fan cooler is burn out .... The Thermistor will shut off the TV automaticly to the unit for Over Heat
Sep 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The Television will not stay on
LOOKS LIKE YOUR CONVEGENCE IC ARE SHORT UNWELD BOTH IC AND TURN TV ON IF IT STAYS ON 450 DOLLASR TO REPAIR
Jun 03, 2010 | Hitachi 43F300 43" Rear Projection...
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Projection TV turns off for a few seconds
Good Day, boattech1;
To my understanding the Model 53UDX10B is a rear projection, that uses no fans. I think maybe your LAMP may be getting weak.
Good Luck, big IRISH.
Jul 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sony Grand WEGA KDF-60XS955 60 in. Rear Projection popped and turned off
the reason your lamp blew so quickly is the the lamp fan has become cloged with dust. this is a known problem by sony and I have done 15 or so of the up grades needed. first look at the lamp door is it discolored and warped. if so have a tech order the up grade kit which includes a new door, siraco fan, thermal fuse, and lamp. the return fan may also be needed. also some service menu changes need to be made with the fan voltages of fan 1 and fan2.
Feb 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Over heating
fan filter is probably plugged with dust, fan blades are also probably covered, unit will have to be taken apart and cleaned, lamp is overheating, probably a good idea to replace that lamp or at least order a new one and keep it for when it does finally die out, good luck with it, hope this helps
Nov 29, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
