Hotpoint WF640P - in permanent 'test' mode?!
Hi,  My son has been fiddling!!  The machine LED says 'test' and goes on a test cyle when I ask it to run a programme.  Has he inadvertantly managed to press the right buttons to activate a test mode or is it the circuits that has gone?  If so how can I get it back to normal again.  Yours Hopefully Anna
Machine has gone into permanent "test mode", how can I fix it
  • 1 more comment
  • nathan191 Dec 27, 2007
    the led screen says test how do i remove it please
  • raarhhan Mar 24, 2008
    I am having the exact same problem.
  • mazbrad Dec 26, 2008
    my aquarius hotpoint washing machine keeps displaying test i have tryed pessing on/off and start and hold buttons at the same time but it still comes up with test
    President:
  • 1,294 Answers
Press "start" & "on" together for over 5 seconds; the test mode will come off.
Posted on Dec 26, 2007
  • 447 Answers
Try unplugging it for 30 mins and power back up
Posted on Dec 09, 2007
  • terri-ann196 Sep 19, 2010
    stil got same prob help
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
The rubber section of my Hotpoint WF640P has gone mouldy
The problem is basically caused by doing too many low temp washes.
The scum you refer to is actually bacteria that is bulding up on the door seal.
To avoid this problem reoccuring, the best thing to do is to have the door seal replaced, and periodically do a high temp wash with powder in, but without clothes..
This is called a maintenance wash, and is recommended by most manufactures
Also, after each wash, clean and dry the door seal, this will help prolong it's life.
Hope this helps answer your question.
Please rate my solution.
thanks.
Dec 23, 2009 | Washing Machines
Test message off my hotpoint
press and hold down the start and the on/off buttons together untill the display says d off then release them.
you will then be able to use as normal.
Aug 21, 2009 | Washing Machines
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860
the applionce is in demmo mode and running a test cycle so you need to cancle the cycle first by holding the start reset button until all the screen iluminates(88:88) now you need to disable the demo mode by holding the start cancle and the on off buttons together until you see D OFF in some cases you may need to hold the button to the top left of the screen and the start and on off buttons but this will sort it
Feb 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
this fault i find interesting, i had a f860p doing the same thing after the power went off, i was told to press both the start and on button together for a few seconds etc, or something like that, it didnt work for me, but it worked for someone else on here who had same machine and same fault
if this cures it for you get back to me and tell me exactly what you did as i still have the machine in storage, i have spare machines
Oct 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
Led flashes on then off
did you find out what this problem was?
Dec 07, 2006 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
353 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
