Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Won't run right
It would not run full power all of the sudden.the fuel lines were worn and I noticed the filter had broken away from the fuel line in the gas tank.I replaced the 2 lines. (carb has 2 lines)Still not running at full throttle and boggs down
  • 53 Answers
Have you checked the tiny stainner at the end of one of the fuel lines inside the fuel tank.
Posted on Sep 08, 2009
Why does my 800 sxr jet ski engine runs full throttle and keeps running even after I pulled the spark plug caps?
dirty carbs !
reeds broken will spit back through the carbs !
crank seals worn can let engine run away !
Jul 07, 2014 | Boating
My xt 250 1981 model wont run proprely
Hi, Champion and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
totalmotorcycle com
1982 XT 250 won rev out dies if WOT Yamaha Dual Sport
Older XT250 Won Run Some Choke
bike dies suddenly Bike Problems XT225 250 Rider Group
Yamaha XT250 XT 250 Service Repair Workshop Manual Download Manuals...
OEM parts for Yamaha
Yamaha XT250 Owner Manual
Feb 17, 2014 | Yamaha Motorcycles
My Husqvarna 41 will run fine for a while (up to 3 tank fulls of gas) then other times it will start and run but then bog down like under a load (but I just holding it and not cutting anything. Other...
Does this describe your problem.? 'Engine does not deliver full power or runs erratically'
Possible faults - Muffler carbonized, Piston rings leaking or broken, Secondary air seepage through leaking gaskets on carburetor spacer flange / poorly mounted or faulty manifold.
Aug 04, 2013 | Husqvarna Garden
I have a 86 Toyota 4Runner, it will not stay running. It will start right away and run for about 5 seconds and then die and won't start unless I leave it alone for an hour or so. It cranks and wil
Good explanation of symptoms.Thank you.
No assumptions.
Diagnose problem.
Pinch off the fuel return line.
Check fuel pressure--I don't wanna!PITA!
The fuel pump won't run if the fuel filter is plugged up.
Toyota's have a gas tank drain plug!!!!!!!!!
My '84 takes a 3/8 " ratchet. Cool.
There may be a fuel pump relay that is toast,but I suspect the filter,off hand.
A plugged filter will overwork the pump and cause the engine to run rich.
Feb 20, 2013 | Toyota 4Runner Cars & Trucks
1990chevy suburban 2500 350 died while driving and won't restart I can hear the fuel pump turn on I have changed the fuel filter and still nothing what's next
check for spark, no spark, no fire engine wont run, possible bad ignition coil, wire from coil to distributor cap, no power to ignition coil from ignition switch (rare) wire broken to ignition coil (even rarer)
Jul 09, 2012 | Cars & Trucks
Where is the fuel filter
The fuel filter is mounted on top of the fuel tank by 1 10 mm bolt. Remove this bolt (Spray some WD-40 on it first, so it won't break on removal). Then, squeeze together the plastic tabs at the ends of the fuel lines and pull the line(s) off. REMEMBER, THE FUEL IS UNDER HIGH PRESSURE AND WILL SPRAY WHEN YOU REMOVE THE LINES!!! KEEP ALL DROP LIGHTS AWAY FROM UNDER THE VEHICLE!!! You'll loose a couple cups full of fuel, be prepared!!. Also, when installing the new filter, put some motor oil on the lines prior to sliding the new fuel lines into place. This will prevent damage to the O-ring(s) in the new filter lines. Make sure the plastic tabs "snap" into place, try pulling on the filter line to make sure the clip(s) are engaged. And as Curious stated, you'll need to know the wheelbase of your van to get the proper filter.
May 20, 2012 | 1998 Dodge Caravan
Engine quit running. Will spin over but not start. Has 105000 miles on it. New fuel filter.
Make sure that you have enough gas in your car. This sounds like common sense but many people don't think to check this before wondering why their car won't start. Try to refill your tank when it is no less than one quarter full, or you risk getting stalled or stuck somewhere.
  • 2 Verify that the battery has a full charge. A battery with a low or partial charge can cause the engine to crank too slow preventing it from starting. Sometimes a jump will fix this problem, but if your battery is more than five years old you should consider replacing it, especially if winter is only a few months away.
  • 3 Check to see if your fuel pump is turning on. This can easily be done by putting your key in the ignition, turning it to the "on" position, and listening carefully with your ear pointed toward the back seat. If your fuel pump is working you will here an electric "whirring" noise for about 2 seconds every time you cycle the key on and off. If you hear nothing then your fuel pump is faulty or not getting any power.
  • 4 Find out if the engine is getting gas to it. Sometimes a plugged fuel filter or a problem with the fuel injectors can prevent the engine from getting any gasoline. To check this remove the air cleaner and smell inside the throttle body or air cleaner housing. If the engine is getting enough gas you should be able to sense a strong gasoline smell due to the amount of uncombusted fuel left inside the intake manifold.
  • 5 Determine whether the spark plugs are firing. If there is plenty of gas but no spark, the engine will crank but not start. Unplug one of the spark plug wires and plug in a spark tester. Have a friend get in the car and crank the engine while you watch to see if the spark tester illuminates. You can usually purchase a spark tester at an auto parts store for about ten dollars.
    Find the fuse box of your Ford F-150, located on the passenger side of the truck under the dashboard. Locate the fuel reset switch that is next to the fuse box with a red cap on top.
  • 2 Start the motor of your vehicle and then depress the red cap by hand at the top of the fuel reset switch to stop the flow of fuel to the engine. Once the engine dies, crank the motor a couple of times to drain all the fuel pressure from the line.
  • 3 Locate the fuel filter on the inside of the frame rail under the driver's side door. Notice the markings on the fuel filter and how it is pointing, so you can identify which way to install the new filter.
  • 4 Disconnect the metal retaining clip by hand from the front (engine) side of the fuel filter and move it out of the way. Compress the metal fitting that sits over the front of the fuel filter with a line-removal tool until the filter comes loose, then separate the line from the filter.
  • 5 Separate the rear of the fuel filter from the fuel line by carefully using the line-removal tool to compress the metal fitting until it come loose, then remove the filter from the line.
  • 6 Use a flat-head screwdriver to loosen the clamps holding the fuel filter in place. Slide the old filter out of the clamps and discard the filter.
  • 7 Slide the new filter into the clamps with the arrows on the filter pointing toward the engine and tighten the clamp with a screwdriver. Connect the front fuel line to the front of the fuel filter by sliding the compression ring back and placing the line over the filter until the ring snaps into place, then move the locking clip into place.
  • 8 Connect the fuel line that runs to the fuel tank by pulling back on the compression ring and sliding the fuel line over the filter until the ring snaps into place, then move the blue locking clip in place over the line.
  • 9 Check all your connections to verify that they are set right and then depress the red fuel pump inertia switch. Turn the engine over by turning the key without starting the engine and counting to 10.
  • 10 Check the fuel line again to verify that there are no leaks. Start the motor and allow it to run until the idle smooths out.
  • Oct 16, 2011 | 2002 Ford F150 Regular Cab
    My sst25 starts hard and stalls...seems to be sensitive to engine position before stalling...stalls when throttle is opened and when just runnung
    Had the same problem with my SST25 and after looking further, noticed something rattling around in the fuel tank. The fuel filter had fallen off of the small fuel line (actually the small fuel line had broken). Removed filter from tank and small piece of broken line from filter connector, and re-connected to small fuel line.
    Jul 11, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    Sometimes there is a loss of power sometimes the
    could be fuel filter or dry-rotted vacuum lines maby fuel sending unit a # of things id need more input .could also be a faulty or loose fuse a few too many areas to look .visually inspect the lines etc for worn or corrosion
    Aug 25, 2009 | 2003 Chevrolet TrailBlazer
    Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
    111 people viewed this question
    Top Ryobi Garden Experts
    Nick Olsen
    Rexter1
    Roland W VanLue
    Roland W VanLue
    Are you a Ryobi Garden Expert? Answer questions, earn points and help others
