Question about HP Photosmart C5180 All-In-One InkJet Printer
How do i fix error message Message 0xc18a0201 on HP photosmart C6150?
  • 3,741 Answers
Common Error Codes:
0xc18a0001, 0xc18a030a, 0xc19a003f, 0xc18a0201, 0xc19a0003, 0×05d1281, oxc18a0307, 0xc18a101, 0xc052281, 0xc05d0281, 0xc18a0306, 0xc19ac3ff, 0xc18a0101, 0xc19a0031, 0xc18a0007, 0xc18a506
Troubleshooting:
When you have one these error messages on your printer screen there are two things that you need to consider to enlighten yourself on what to do when you are in this kind of situation.
Is your product in warranty or out of warranty?
For In-Warranty products, please do not do any self troubleshooting. Immediately contact HP technical support to have them troubleshoot the problem for you. In most cases, printers with these error messages are replaced but you must also be patient and follow the technical support’s instructions and basic troubleshooting. I recommend you to read our article on how to contact HP technical phone support.
For Out-of-Warranty products, I am afraid you have to exert extra effort to be able to resolve this issue on you HP printer. Below are ways that I recommend to resolve this.
You need to do some basic troubleshooting steps below and hope that it would fix the problem.
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify product is functional.
  • Reconnect the USB cable, and try to print from the computer.
  • If the error is still there continue reading…
Generally, when you have this type of error message displayed on your printer screen your printer may be permanently damage, resetting your hp printer may fix it in some cases but it is almost certain that the problem wil reoccur.
“0xC18′ errors may also mean that the printer’s temperature is below 40F/5C.. Try warming up the printer and try again. If you have reached this part already and still the problem is not yet fixed, do not worry I still have 3 more suggestions to help you with this problem.
1. Chat for free in real time with an HP online support agent. Hopefully, HP can be able to support you on this.
2. I have stumbled upon a solved problem at fixya wherin user SagarJD was able to provide a special reset for the ink system and was able to successfully solve the ink system failure with error:OXC18a0205. You can try following his procedure.
3. If you have reached this part already, then most probably your product’s Ink System is permanently damaged and it is certainly unrecoverable. Servicing the printer is not what I recommend on this. Instead, I suggest you call HP tech support and upgrade your printer to newer model.
By the way, there is another way. By now you are getting ready to replace your printer, right? Why don’t you this last solution, and try it to resolve this issue. This step is only intended for OUT-OF-WARRANTY products ONLY as doing this step on IN-WARRANTY products can VOID YOUR WARRANTY. Do this step at your own risk.
There is a CMOS battery inside your printer that keeps track on your printer’s history. Ink replacements, resets, etc… Try resetting the data stored on your Hp product by removing the CMOS battery and then putting it back in after 30 minutes.
click this link directly to see the exact location of CMOS battery
http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 08, 2009
Hp photosmart c6150 all in one error oxc18a0206
hey, with this document you will be able to fx the printer if you ever got a message like ink system failure 0x...
on hp printers
http://rapidshare.com/#!download'253l34'140957209'Assert__Ink_System_Failure_Actions_for_PhotoSmart_Six_Ink_Products.doc'258
Mar 03, 2011 | HP Office Equipment & Supplies
Hello. i have the hp Photosmart C6150 printer. for
Press the button on the printer, to turn the printer off.
Then, press the switch on the power-bar, to completely cut the power to the printer.
Turn the power-bar on.
Turn the printer on.
Jul 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
Error message 0xc18a0201
try to reinstall your printer and if the error message show up again try to check your printer to the HP customer care mybe the problem from your board printer
Apr 09, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP PHotosmart c6150 keeps shutting on and off repeating the same meassage improper shutdown.
You need to reset the printer. I had the same exact problem with a C6150. Unplug the power cord from back "while printer power is on" (doesn't have to be fully booted just turning on). Wait 20 seconds, hold # and 6 keys together and plug power back in. Continue to hold until power goes off or semi-reset message comes up. Power up (if off) press OK for any error messages and let the printer cycle. Should be good to go. Mine sounded very noisy while it was trying to allign internally. I can only suspect that was the initial problem but this process fixed mine and it runs great now. Hope this helps.
Jan 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a c6150 all in one hp with a oxc 18a0206 error code how do I fix
goes through below link i think it will help you
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Photosmart-C5180/m-p/130071/message-uid/130071
Dec 08, 2009 | HP Photosmart 3310 Printer
On HP Photosmart C5180 Error Message 0xc18a0201
call hp total care 1800 4746836
u knw i cn tell u the steps but if u do even 1 of the steps wrong ,ur printer wont work anymre so contact them
...hp technicians will be able to take care of u
thanhks
Aug 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
Installed new computer - keep getting error - HP Photosmart C6150
Try
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
