Question about Garden
Carb loading up with gas on 8.5 Briggs & Stratton. Used it 1 year ago, ran fuel dry and now fuel loads in carb. What is best fix?
  • 22 Answers
Tap on carb bowl a few times float sticking if this don,t work remove bowl and clean neddle valve and seat phone 912 223 0054
Posted on Sep 13, 2009
  • 155 Answers
Sounds like the float needle is stuck open you can take the carby bowl off and check it, You can find a carby breakdown on a site called pats small engines.
Posted on Sep 12, 2009
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How do I fix my push mower with a Briggs & Stratton engine?
Its obviously a fuel starvation issue, so there is still some blockage in the carb, re move the carb and see if your frendly local dealer will clean it in there sonic cleaning tank, if not soak with carb cleaner and blow the jets through.
May 11, 2012 | Garden
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
19 hp Murray garden tractor won't run
no sounds like your carb needs a real good babtising! good look!
May 19, 2010 | Briggs & Stratton Garden
2004 v twin 16 hp 500hours on it runs but spits fuel throught carb when giving gas runs like its missing on one cylinder replaced carb, plugs, fuel filter, it has 120 lbs of compression in each cylinder...
You should take one of the heads off and look at the valves. You may have deposits building up no the valves.
120 pounds compression sounds pretty good for a six year old engine with 500 hours on it. It probably started life at 9 to 1 and now is around 8 to 1.
May 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
