Question about Dell Spacesaver USB Keyboard J4624 SK-8115 RT7D50
Teclado dell modelo SK-8115
Tenia vista, lo pase un original de XP, se desconfiguro teclas del heno y que no funcionan, que debo hacer.
tekkydidi
  • 37 Answers
SOURCE: dell sk-8115 not recognized on boot up. After soft boot it works
hi im Dyanne.. on th 1st screen at bootup press th desired key to display th BIOS setup. on some machines you will see a brief notice on th screen as it comes to life stating which key to press. (ie. delete, F2 or esc etc) if not consult your instruction manual. you will get to a blue screen headed CMOS. now you need to setup th BIOS to recognize th presence of th new h/d. this will enable you to auto detect th h/d. go to th 1st in th list (cmos settings) and where it says PRIMARY MASTER click on it and enter and this will auto detect it. press F10 then Y and enter. this will now access your h/d and boot normally. good luck and merry christmas .. Dyanne xx
Posted on Dec 25, 2008
  • 4 Answers
SOURCE: Dell keyboard SK-8115
(That is the the Num Lock indicator, nothing to worry about.) If it is not working it is likely because USB keyboards can time some time to be recognized by windows, let the computer boot up with the keyboard connected and let sit for up to ten minutes.
Sometimes if other hardware is detected at the same time which requires drivers to be installed, windows will never proceed to installing your keyboard, however you cannot install the other drivers until you have a working keyboard. To solve this, you will need to use an older style PS/2 keyboard to get everything installed and working as they do not need to be detected.
Posted on Jan 08, 2009
robshow
  • 367 Answers
SOURCE: Dell SK-8115 USB Keyboard on none Dell PC Issues
Have you gone in and removed the usb drivers by doing the following.
1.) right click on my computer
2.) select properties
3.) Select Hardware tab
4.)Select device manager
Then remove all instances of usb that you can.
You may have to try this using just the mouse for navigation. Right click on usb item then select uninstall. Remove all the ones you can then reboot the computer. You may have to reboot a couple times
Then try the keyboard it should work no problem
Posted on Jan 16, 2009
yooperbud
  • 8637 Answers
SOURCE: Dell SK-8115 USB keyboard on non Dell PC
Normal 0 Are you using Windows Vista? (This may still work if your using XP) If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
koriwilliams
  • 10 Answers
SOURCE: how do I mute my Dell SK 8115 keyboard
What do you mean? Keyboards can't play music or sound unless you're talking about a laptop.
Posted on Nov 27, 2009
Necesito programar mi television sanyo pero no tengo control remoto
Hola Rodolfo, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor contacteme a kimberly.escobar@dish.com.
Dec 26, 2012 | DISH Network IR Remote Control
Nesesito los diagramas de fusibles y relais de la camioneta nissan np300, por que la bomba de gasolina trabaja y despues de un rato se apaga ya se ha cambiado en 3 ocasiones el repuesto de la bomba de...
Necesitar? marca, modelo, a?o y tama?o del motor..y quiero saber m?s sobre lo que est? pasando?? Tendr? que marca, modelo, a?o y tama?o de motor .. y me dice m?s acerca de lo que est? pasando? Necesito hacer, modelo, a?o y motor...¿y m?s informaci?n sobre lo que est? sucediendo?
Aug 22, 2011 | Nissan Pickup Cars & Trucks
Teclas 2,w,s n funcionam
Podrias tener un problema en el conector del board donde enchufa el "flex" que sale del teclado. Primero debes sacar el teclado, desconectarlo y volverlo a conectar, OJO que estos conectores tienen un sistema de traba muy delicado que tenes que liberar antes de sacar la cinta y volver a trabar cuando la repones. presiona sobre diferentes lados del mencionado conector mientras pulsas las teclas, a veces solo son falsos contactos por suciedad, o en el peor de los casos, alguna soldadura mal, por lo que habr?a que resoldarlo, lo cual es muy delicado y requiere de herramientas y habilidad especiales.
Para la limpieza, te recomiendo una mezcla de alcohol con agua al 50% y pasarlo sin mojar mucho la zona con un cepillo de dientes, luego pasas un hisopo o algun pedacito de trapo para secar bien y lo dejas que evapore, por las dudas unos 20 minutos, podr?a ser mejor mandarle aire caliente de un secador de pelo por un rato.
Dec 09, 2010 | Toshiba Satellite A200-0ET00X Notebook
Hola espero puedan ayudarme... mi telefono no le funciona la pantalla tactil y se me kedo blokeado asi ke le di un hard reset y todo bien pero el problema no termino porque ahora para iniciar el telefono...
hay muchos htc g1 que tienen el mismo problema parese que nadie pouede darle solucion.... yo tambien tengo un g1 pero no se que puede pasar.... ando en tar de solucionar el problema... que sera...
Sep 18, 2010 | HTC G1
Imac g5 linea blanca vertical en la parte derecha
éstos son algunos procedimientos que se pueden tratar de resolver este problema con la línea blanca de la pantalla. Pero, por favor tenga en cuenta: si estos 2 procedimientos no ayudan, te recomendaría tener en tu Mac en el servicio de Apple en un centro de servicio autorizado
éstos son algunos pasos que usted puede tratar de resolver el problema:
Opción # 1
-PRAM reset -
• En primer lugar, sostiene en su botón de encendido durante aproximadamente 10 segundos para hacer una parada difícil, si no se ha cumplido ya su Mac apagado.
• Una vez que tu Mac está apagado, usted tendrá que realizar lo que se denomina un restablecimiento PRAM (RAM de parámetros)
• Busque las siguientes teclas en el teclado: Comando, Opción, P y R. Es necesario mantener estos teclas simultáneamente.
• Encienda el ordenador.
• Mantenga pulsado el Comando + Opción + P-R llaves. Debe pulsar esta combinación de teclas antes de la pantalla gris.
• Ahora, presionando las teclas hasta que el equipo se reinicia y se oye el sonido de inicio por tercera vez.
• Suelta las teclas y permitir que el MacBook a poner en marcha.
Opción # 2
-Restablecer la PMU -
El administrador de energía es un circuito integrado (chip de ordenador) que suele ser en la placa lógica de su ordenador Mac.
Es responsable de la gestión de energía de la computadora. Controla la retroiluminación, giro del disco duro, el sueño y la activación, algunos aspectos de la carga, control de trackpad y algunas entradas y salidas en relación con el reposo del ordenador.
• Si el ordenador está encendido, apágalo.
• Desconecte todas las conexiones de entrar en el Mac, excepto para el cable de alimentación.
• Una vez que todas las conexiones se han desconectado, quite el cable de alimentación de la Mac.
• Espere 20 segundos.
• Vuelva a conectar el teclado, el ratón y el cable de alimentación en el equipo.
• Presione el botón de encendido para reiniciar el equipo Mac.
Espero que esto haya ayudado a resolver el problema de la línea blanca.
Recuerdos,
-Mactechtrainer
Jan 29, 2010 | Apple iMac G4 Desktop
Mi problema es que yo compre el control remoto que es rcu600wms que era compatible con venturer dvd sts 75 e home theatre en el listado apararece no asi donde estan los numeros de codigos con el tv si...
el problema de los controles universales es que casi no funcionan con los dvd´s y cuando lo hacen hay que buscar que tecla hace cual funcion le recomiendo que busque un original
Dec 09, 2009 | RCA RCU600WMS Remote Control
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
No funciona
Ulises,
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
Computers & Internet Logo
349 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
