Question about Toshiba Satellite L350-ST3701 Notebook
Hi i have a e750 video grabber and have installled all the software on the computer. However when connecting up the video machine to the laptop, i cannot get a picture only the audio. Any idea's of how to resolve this? thank you Roger
  • 2 more comments
  • darkhorse_44 Sep 10, 2009
    Hi i have checked where the cables should go and theres only one place on the video machine where all 3 phono leads could go which is av2. Yet when i try it on the laptop i can get sound but no picture. Is there anything you can suggest that would enable to get me a picture on my vcr? i have tried everything i can think of yet it still doesn't work. Any Advice would be brillant. Many thanks
  • darkhorse_44 Sep 12, 2009
    Yes i am definately using the phono leads (rca plugs) the red and white work perfectly but the yellow doesn't seem to be giving any picture. Looking at it the vcr only has the white and red audio out but not one for the yellow lead this is probably why. I have a scart adapter to run these into the back but that doesn't seem to work either. I live in england and the vcr is the standard pal version. I have a s-video lead but the vcr doesn't want to accept that it seems. I own 3 vcrs in total and have tried all of them with the same result is there something else i'm not doing? or something i could do to rectify this problem? Thanks for all your advice so far. Roger
  • Hobit May 11, 2010
    I hate to keep harping on this but, I assume you are using the RCA plugs and you have the software running on the laptop. You should have three cables, yellow (video) and white/red (audio). If the VCR (note that vcr is not the laptop screen) can output to a TV screen then it should work to the capture device. Watch as you disconnect each cable from the TV to be sure it is video or audio (have VCR running). then connect them to the capture device as you disconnect them from the TV (you may want to be sure the video gets to the yellow plug). You do not say what country you are from, but make sure the PAL, SECAM or NTSC is correct on the device. Also be sure the video source you want to capture is not copy right protected. It is also possible that the capture device is defaulting to s-video input VS RCA. Check settings. These are the most common problems. If it is not one of these it is a bit more difficult to trouble shoot.
    First thing is to be sure the cables are in the correct ports. (I have seen where one of the audio is in the video.)
Hi, I'm having the same problem with my device and I was just wondering did you ever solve it??
Posted on Jan 23, 2010
What I have to do at my Sony Hundycam DRT-TRV75E.My laptop don,t conntct to camera.There is no good files.
if your camera and laptop are OK, then you use a video grabber unit to connect with your laptop, you will get the needed software with it. costs $30 only.
Nov 16, 2015 | Sony Handycam DCR-TRV250 Digital Camcorder
Ez grabber i hear vhs thru computer but only see blue screen
The video head is dirty or there is a compatability issue with the vcr to the computer. Buy T120 blank tape, set vcr tape speed to sp, put blank tape in the machine and press the play button and let play right through, repeat if no change, if after the second run there is no improvement, check the video cable connection from vcr to computer, if okay! maybe compatability issue.
Apr 12, 2012 | Computers & Internet
Can i connect a samsung camcorder vdp453 to windows7 pls?
Most of these camcorders do not have proper usb support for video, so you'll have to buy a so-called video grabber or capture card. You can plug in the video grabber to usb and then connect dvi or firewire from your camcorder. Install the included software, configure your camera. Then press play and the video grabber will record the input from your camera.
When you buy one of those video grabbers, make sure it's a good one. Make sure powerful and stable software (which is compatible with windows 7) is included. Cheap things usually don't work. I've had this Chinese piece of junk for $10 which lagged and kept crashing my computer. Pinnacle was a lot more expensive but it works great and the fun will last a long time.
Jun 17, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
I need a driver for easycap usb capture card
http://www.szforwardvideo.com/support/index.html
That should link you to the drivers for your usb capture card. I believe the category you must select is "
USB Video & Audio Grabber". Make sure you choose the correct model. The directions should be pretty straightforward to follow. If you can't find the directions, I've posted them below.
• Download the DC60+ Video grabber with audio drivers and utilities file to your computer.
• Unzip this file to a directory you will remember, such as DC60+.
• Uninstall the old drivers for Video adapter with audio from your computer at first, and leave your DC60+ Video grabber with audio plugged into your PC or laptop.
• Run setup.exe, from the directory file.
• Plug DC60+ Video grabber with audio into your PC or laptop, and click "OK" or "Next" to update the latest drivers. Please find the installation step through Quick Installation Guide or Software and driver CD.
Name: dc60+ driver.rar
Mar 22, 2011 | Computers & Internet
I have a EZ Grabber but do not know how to work it.
had same problem. ensure right selections are made in the souce menu. & that your connectors are out connectors and not ins.
Sep 18, 2009 | Ulead Videostudio 8 for PC
Installing the 2.0 e750 video grabber and getting a picture
I also have this problem with the E750. i only have 2 audio out connectors and a scart connection on my video. how do I connect a video lead to my pc.
Sep 06, 2009 | Toshiba Satellite L350-ST3701 Notebook
Cannot install hardware at the beginning
if it will allow you to install the software first do so reboot the computer when windows is up then plug the device in.
Good Luck
Sep 05, 2009 | Computers & Internet
Vcr to dvd
Hi you could install a Video Grabber or an Internal TV Tuner card into your computer if its Desktop computer or an expensive USB TV TUNER if its for laptop . Plug in the composite video out from your VCR to the Composite Video in to the computer .Use nero or any other software to build a movie in fact the bundled application software of your TV TUNER or VIDEO Grabber card would be better .
May 09, 2008 | Dell Inspiron 5160 Notebook
Hi8 to Computer for editing
Color: Black Part No.USBG-VX3 VISTA COMPATIBLE USB Video Adapter USB 2.0 Audio/Video Grabber S-video& Composite
AUDIO AND VIDEO GRABBER FOR WINDOWS VISTA GrabBee X+ USB 2.0 Audio/Video Grabber New Generation USB2.0 Audio/Video grabber is the best ideal companion for your portable audio/video application. Real-time MPEG 1/2/4 recording make you have powerful video application on hand. GrabBeeX+ USB 2.0 A/V Grabber is the bridge between your computer and analog camera, VCR, camcorder or other video source. GrabBeeX+ USB 2.0 Video Grabber is small enough to fit in the palm of your hand and is ideal for both notebook and desktop computers. Applications : Video recording & editing Take photo Video email Security monitoring system Features : Small Wonder--Dimensions are (L)81mm x (W)30mm x (H)15mm Audio and video go though USB 2.0 bus (WinXP) to make best performance High speed USB 2.0 data transfer rate for best video recording Encoding MPEG 1 or MPEG 2 format directly use InstantMPEG Technology, Ideal formats for creating VCD or DVD movies Up to 25 fps motion capture capability at 720x576(PAL) & 30 fps at 720x480(NTSC) SnapShot function support Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Recording period setup Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Support Brightness, Contrast, Hue, Saturation, Sharpness control Powerful video editing function include Motion Video Special Effects/ Title Effects/ Picture-in- Picture Effects/ Slow & ast Motion Video Effects/ background music/?color background/ Transitional Effects Plug & Play Low power consumption. Ideal for portable computer too No Battery---No need to install batteries or run off the wall adapter
  • Specifications : Video input : One RCA composite, One S-Video.
  • Video system : NTSC, PAL and SECAM multi system support Audio input : in WinXP, go through USB; in Win2000, go through sound card
  • Motion capture : AVI format from 160x120 to 720x576 resolution MPG format from 320x240 to 720x576 resolution Still image capture : BMP/JPG/TIF/PCX/TGA file format
  • Performance : Up to 25 fps at 720x576 for PAL, 30fps at 720x480 for NTSC Power Source : 5VDC,300mA(max) through USB port Minimum System
  • Requirements : USB 2.0 equipped computer Pentium 4 1G or above 128MB of RAM Windows 2000/XP Sound card
  • Package Contents :
  • GrabBeeX+ USB 2.0 Audio/Video Grabber
  • GrabBeeX+ drivers CD
  • Ulead VideoStudio editing software
  • User's manual
    I have heard this works, going to try one today, I have tried EVERYTHING else, downloading drivers, diffferent programs, firewire cords, so I think this will work, when I googled our specific camcorder, this matches, also, some people are selling the exact sony camcorder on ebay with this included, stating they have used it to connect to their pc. Hope this helps.
  • May 06, 2008 | Sony Handycam CCD-TRV608 Camcorder
    Toshiba Satellite L350-ST3701 Notebook Logo
    430 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
