Question about Panasonic PT-47WX49 47" Rear Projection Television
Tv won't turn on
Small vertical box shows in top right corner for a second then screen goes completely black again. power button flashes on and off red. I am not sure if my tv is a rear projection or a simple plama tv. It came with my house and is built into the wall. It is a 52 inch screen.
  • 3 more comments
  • dullahbugg Dec 13, 2007
    This is so weird mind did the same thing 2 days ago. I wonder if this thing has a reset button.
  • alliott Jan 12, 2008
    Mine did the same thing a week ago. I wondering also if the tv has a reset button as well.
  • Anonymous Jan 19, 2008
    Ours started doing the exact same thing last night. Any thoughts on what the problem is?
  • Anonymous Feb 01, 2008
    I also have the same problem and at the same time, mine went down a week ago. i took off the back and took a look while powering on and one of the resistors? on the tuner board on the left started to glow red hot then click like normal and it goes into shut down mode. something is shorted out and is causing the circuit to heat up. what is weird is all of these failures at the same time I've seen the same complaint on other web sites and they all started around sept 07 through the present.its almost like it has a built in life timer or a certain amount of on off cycles in it and thats it (planned obsolecence). this is not the first time I've had trouble with it, the cyan driver went out and the color went wacky $1200 for the tv $400 to fix the cyan driver now estimates are around 400 again to fix the problem if the parts are available (2002 tv). new 50" plasma at wal mart in my future.
  • Anonymous Feb 23, 2008
    just brought new panasonic plasma tv got it home tv comes on the switches itself to standby with red light flashing help!!!
    President:
  • 4,402 Answers
Unplugging overnight resets the TV.
convergence ic are the most likely gone bad
however it could also be
that you lost power regulation....or you have what seems to be excess Hi Voltage or arcing
Now the regulator could be at fault or your SENSE line could be falsely triggering due to a change in a resistor or zener diode or even a bad sense line from your splitter...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Jan 30, 2008
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Feb 20, 2017 | Samsung UN55HU7250 Curved 55 Inch Ultra
Panasonic TC-P50VT20 blank screen with vertical lines
http://electro-medical.blogspot.com/
Apr 05, 2017 | Panasonic Televison & Video
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Dgm ltv-1961wcr tv, when powering up the screen comes on for about a second, then goes black?
It is a Lcd lamp problem or even the lcd panel try to see any reflexion of the image , if u see one is the lamps, if not then is the lcd panel and if it is then is garbage.
Apr 23, 2012 | Digimate Televison & Video
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Black Lines
Just to reset first before proceed another procedure;
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet for 4 - 6 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
Oct 07, 2008 | Hitachi 61SWX10B 61" Rear Projection...
It's not working!
It seems to be a software failure. Try using your recovery CD to sort it out. If it continuous then i would recommend a clean install if there's nothing that important on your laptop.
-Aaron
Aug 08, 2008 | Acer Aspire 3680 Laptop
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
