Question about Motorola Mobility Hint QA30 Cell Phone
My volume button doesnt work. I can turn it down, but not back up. Is there another way i can turn it back up? I dont want to wait to have it repaired. I've had it only 2 months.
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Unlocking keypad lock
You're going to have to do a hard reset...THIS WILL ERASE EVERYTHING ON THE PHONE (not the sd card)
Make sure the phone is off, hold the power button, volume down and the back button (third button from the left on the bottom) AT THE SAME TIME, hold and wait, once your in the back menu use the volume button to scroll down to factory reset use the power button to select, use the power button again to scroll down to yes, and power button to select, just wait, with will shut down and turn itself back on, takes about 5 minutes to restore function. (I worked for Cricket for a long time and I know the phone well)
Oct 08, 2013 | Cricket Wireless Cricket Samsung Vitality...
Zte x501 locked forgot passcode
Sep 01, 2013 | Cricket Wireless Cricket - Zte X501 Groove...
Wont start up the screen only displays the android logo i've tried pressing the reset button many times but still the same
Try a master reset:
  • Turn off the unit.
  • Plug the unit into an electrical outlet.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Oct 08, 2011 | Coby Kyros 7" Touchscreen Tablet
My canon powershot SD280 sound wont work.. The sound turn on Okay, but the Video doesnt = It DID work and i dont know what happen to it !
hey boss- just figured this one out.
while the video is playing, you can increase the volume by pressing the button above the Func. Set center button and decrease the volume by pressing the button below the Func. Set button. Think we both accidentally turned the volume all the way down.
Too bad you can't tell this by going to the volume menu! Would have been nice to know I was still recording audio while shooting video. Hope this helps!
Jan 24, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Button to turn op the volume of Samsung Star doesn't work..
If it is in warranty you should reach the dealer and get it repaired free of cost. dont wait
Nov 08, 2009 | Samsung Star GT-S5233 Cell Phone
How do u turn up master volume on moto q?
just press and hold down the side toggle button on the side of the phone and wait until the volume control appears. thhen turn the volume completely up
Oct 22, 2009 | Motorola Mobility Moto Q
Remote, menu button, volume up buttons dont work anymore
You need to open the remote unit and clean the touch pad contacts and the circuit board contact points with pure isopropyl alcohol.
Grease may have worked itself into the remote an has caused those button contacts not to produce the data signals.
Nov 17, 2008 | RCA F32650 32" TV
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Motorola Mobility Hint QA30 Cell Phone Logo
130 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
