Question about Garden
I have toro 6.5 super/recycler that stalls out after about 5-10 minutes after it starts up then it will not start for about 30 mins. i've changed the spark plug and cleaned the filter
My toro recycler lost its self propelled, too hard to push.
Posted on Sep 20, 2011
    Scholar:
  • 110 Answers
Check the vent hole in the gas cap. A partial vacuum in the tank will cause this.
Posted on Nov 02, 2009
Dont know if this is the same problem but it may help. I've recently bought a used Toro 6.5 recycler and have cut the lawn 3 times with it. This third time it began to stall out on me. If I hit the primer button several times it would start up but then die again. I thought I'd have to pull the carb and clean it, ut after looking at a few problem listings online I realized it was probably just some trash in the needle valve. I managed to get it running again by first pushing the primer pump 3-5 times, then pulling the cord to crank it, then while holding the contact bar in place with one hand to keep it running I reached down and pumped the prime button a few times before it cut out again- after one or two tries it apparently flushed the trash out and it ran fine again. Had the same problem later and fixed it the exact same way, then went on to finish the yard.
Posted on Sep 29, 2009
  • Bill Scott Jun 06, 2013
    Thank You, VFM-mower. I read your solution, went out and tried it on my mower which was having the same problem, fixed it the first try. Like you said to do, I primed it, held on to the handle, primed it again before it chugged out, then finished mowing the lawn. Ran perfect.
Starts, then stalls after 10 min
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward. Also check out the links below
Small Engine Repair Help
Lawn Mower Troubleshooting Guide Engine
May 03, 2015 | Toro 20372 Recycler Personal Pace...
Toro personal pace mower will not stay started?
If ir starts and runs for only a few seconds it's a dirty carb/bad gas. Drain the fuel system and use FRESH gas; change out your fuel supply monthly to avoid "phase separation" issues. If it runs for several minutes and then dies it is possibly a sticking valve. Do a compression check cold and after it stalls to confirm. Hope this helps
Mar 08, 2015 | Toro 20372 Recycler Personal Pace...
I have a toro recycler 6.0 push mower and I can't seem to get it started changed the plug but still won't start
get the old gas out of tank and carb....put new gas in...wait 2-5 min....spray starter fluid into carb --one decent squirt....it'll crank....
Jun 09, 2014 | Toro Power Lawn Mower
How to determine the oil level on dip stick
In other products, the upper hole is max and the lower hole is min. Somebody at Toro forgot to change the manual when the dipstick was reengineered.
Apr 23, 2014 | Toro Garden
Toro super recycler
Push primer bulb at least 3 times. Pull starter rope until it starts. Ensure safety lever is engaged on handle.
Aug 02, 2013 | Garden
Starts and runs great(when engine is cold).\r\nafter 15 mins the engine dies. will start up again, but will only run about 5 sec. and then dies. toro super recycler 5.5 hp GTS5
I would check the gas cap. If the gas cap is plugged or pieces missing from inside it will not allow air into the tank and the fuel will not flow properly to the carburetor. Just loosen the cap and try it, if it does not change check for dirt in the fuel line.
Jun 15, 2011 | Toro Garden
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Jul 21, 2010 | Toro Super Recycler Super Bagger Lawn...
Toro Lawn mover 605 recycler
Your carburetor is definately dirty or it needs new gaskets, screen, and needle valve( carb. kit). Is this something that you think you might want to attempt? It really isn't that difficult. Can be done in about an hour. If so, let me know and I can give you a few tips.
Jim
May 28, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,062 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
