Question about Samsung Office Equipment & Supplies
Spots along left side of page. On every printed page there are black spots along left side.
    Novelist:
  • 110 Answers
Something on the fuser... is it the same distance from each spot every time?... then something is on the fuser roller, so it gets fused every time it rolls over that spot. thats my guess
Posted on Sep 08, 2009
Lexmark t-620 print spots
That usually indicates a worn heat roller in the fuser assembly. You can get a fuser from Amazon or other online site. They are user replaceable and run about $80-100. Do a search for T620 fuser and you will find them. Part number 99a2402 What happens is the Teflon coating on the fuser wears down which allows the toner to stick where is should not stick so it gets deposited on the paper in other locations and leaves spots.
Apr 18, 2013 | Lexmark Office Equipment & Supplies
What can we do about dark toner spots that are appearing on the right side of documents we print? We have tried using a can of air spray to clean the inside of the printer, but to no avail.
I have a Brother HL 4040cn color laser printer and I had the same problem. On every page I printed there were these black dots that appeared down the right side of the page in regular intervals. I tried the automatic drum cleaner and that didn't work. I opened the printer from door, removed the black toner cartridge and looked at the drum. Sure enough there was a speck of black crusted toner stuck to the drum. I used a q-tip and lightly scrubbed at the spot to remove the toner then I used the gear on the left side of the drum to rotate it and check for any other smudges and there were none. Put the toner cartridge back in and it was good to go again...no black dots!!
Hope this helps someone because I couldn't find the solution myself when I searched.
Sep 22, 2010 | Brother Office Equipment & Supplies
Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Jun 04, 2009 | Lexmark E232 Laser Printer
BLACK LINE ALONG RIGHT SIDE OF LETTER SIZE PAPER
Is this and Okidata C5100? And is the stripe vertical up and down on the page? I'm going to assume yes to both of those for the sake of trying to help. Worse case is the fuser unit in the machine is wearing in one spot and thats why the streak is appearing. Also, many color printers require a seperate drum unit or photo conductor unit. These could have a wear spot on them as well. They can fail long befor the change drum light appears. Other than that remove and inspect the black cartridge. If there is a shutter on it, pull back and inspect the two inner rollers. You're looking for any wear spots in a location that corresponds to the streaks on the paper...or an excessive amount of toner leaking from one spot on it. Hope this helps!!
May 21, 2009 | Office Equipment & Supplies
Black spots of the left side of the print
If you know how to remove your drum cartridge, take it out and check if you don't see your black spot on your drum....If so, replace your drum cartridge.
You may have a bad fuser to....
let me know !
Apr 01, 2008 | Samsung Laser Multifunction Printer Toner...
298 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
