Question about Dryers
My dryer is not heating well I think that the lint compartment is full and it seems to be hot towards the bottom of the dryer. I would like to know ho to get the lint out of the bottom of the dryer.
    Problem Solver:
  • 7 Answers
You need to unplug it and remove the dryer vent pipe from the dryer. You should be able to see lint backed up there, or more likely, the vent hose leading to the outside need to be cleaned out as well. I use a shop vac or a brush on a stick. I have a cob web brush on a telescoping pole that works really good for me.
Posted on Sep 08, 2009
My electric dryer won't dry clothes. Doesn't get hot, what's wrong with it?
how is the lint filter maybe it is too full of lint and the dryer will not heat up to protect you from burning doen your house when the lint filter gets too hot and catches fire. Just a thought
Oct 28, 2014 | Dryers
Clothes dryer overheats & shuts off. Works fine again after a cool-down period. Any suggestions, for a non-handy woman with few tools and less money for repairs?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Oct 16, 2014 | Dryers
Whirlpool Vantage dryer lint screen will not slide securely into place. It sticks out about 1/2 an inch. No lint reside is in the bottome of the compartment. What could be the problem?
Check the leading edge of the screen itself to see if it is expanded. Then, once again check the full debth of the slide there must be something all the way at the leading edge that is stopping it, probably compressed lint. You may have to use a flashlight and long thin piece of wire to fish out the glob.
Jan 20, 2013 | Whirlpool WGD7990XG Vantage High...
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
Dryer suddenly does not produce hot air
have the exact same problem, just over 1 year old no heat! first off my duct work under my floor is like a snake and is not a straight shot out of the house. I beleive this caused a ristriction in the venting because dyer seemed to be running hotter them normal. I took the top off the dryer and pulled the vent tube out of the bottom of the dryer. To my surprise found a three inch layer of lint on the bottom of the machine and also on the heating coil. After cleaning out all the lint i took a volt meter to the two wires that come down to the heater. started the dryer and found i had 220volts at the heater indicating the heater is out, found one on ebay for about 50 bucks. will be installing this weekend and will let you know how it works.
Mar 08, 2010 | Samsung DV218AEW Electric Dryer
Dryer runs for a while does not heat then kicks off but lights flash
Howdy: It seems that the fire ignitor is not turning on which turns on the element for heat. Also check the inside back of dryer to remove lint build-up. That to will think the dryer is too hot and shut down. - Good luck - Doug
Dec 08, 2009 | Frigidaire GLEQ2152ES Electric Dryer
How To Open Bottom of Dryer
Take the back cover off and there is a compartment that hook to the hose, with the right tools you can pull the compartment out and clean it to include other parts showing. hope I helped allittle.
Mar 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Brand new electric dryer suddenly does not dry well
hi , still on warranty if you let any body the machine the warranty will invalid , you may call technician where you bought that machine .
Jan 25, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Dryers Experts
