Question about Garden
Riding Mower Won't start for at least 30 minutes after shut down. Seems like the carb. floods. Then starts rough as RPMs increase to normal operating range.
Problem solved. You want me to tell you how I solved it for free??????
Don't you charge customers for solutions to problem???????
Posted on Sep 09, 2009
Mower won't start after short use
have you change your air filter for the season check anything to do with your carb area to much dust in air can get in to carb causing to engine to work harder
Jun 05, 2012 | Briggs & Stratton Garden
Riding mower stalls out
clean the jets in the carb
May 07, 2012 | Garden
Engine seems to flood out when increasing speed and dies
If it starts lightly smoking black smoke at high RPM it is flooding or getting too much fuel. The float is leaking you may have not set the float height correctly when you put that carb back together. Or the needle and set could be bad.
Sep 11, 2009 | Briggs & Stratton Garden
17hp b/s intek OHV after 30 min mowing starts running rough
if gas is in the oil the needle and seat in the carb are bad or some thing in it. the gas will go in to the crank case and load the cylinder with gas. you can take the carb apart to see if something is in the seat. or replace the carb
Jul 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Riding mower having problems starting then runs roughly
I would bet you have a fuel problem. Either the carb is clogged and dirty or needs adjustment. Try opening the screw on the bottom of the carbuerator about a half turn see if that improves it. Also check the air filter and clean it.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
MOWER WILL NOT RUN AT FULL POWER .
try empting the feul tank and put fresh feul in with a little dry gas treatment if that dont work try getting some carb cleaner in a spray can start mower and gingerly spay into carb trying not to over flood it keep spraying untill running smooth change CRANKCASE OIL and AIR FILTER.
Apr 25, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
