Question about Kenmore Refrigerators
When replacing thermostat in freezer which line does it clip on to
  • 93 Answers
Your best bet would be to take the freezer wall off after it has run for a while and look at the two lines. Put it on the one that has the most frost on it. Technically it really will not have a huge affect on which one you put it on, but the colder line will close the thermostat a little sooner. Really the thermostat is just to keep your defrost heater from melting your refrigerator.....When in gets warm enough it cuts power to the heater.
Posted on Sep 13, 2009
Testimonial: "thank you VERY much!!!"
How do you gain access to the thermostat and defrost element
you have to remove everything from the freezer and remove the back panel, usually has 4 to 6 screws and your thermostat has 2 wires going to it and is clipped on the line going to the coil. The element is under the coil with a wire on both ends. If you have a multi meter you can check both. The element should read close to 0 if it is good,if it is bad the meter will not change reading when a leads off the meter are attached to both ends. the thermostat is checked the same way except if at room temp it will not show a reading and if you put it in a glass of ice water when it reaches around 32 degrees it should read 0 or close if it does not then it needs replaced. hope this helps
Apr 17, 2014 | Freezers
Westinghouse Freezer Model FJ303QL9 won't defrost
remove the back panel inside the freezer, the thermostat is clipped on the line going to the coil, you will have to check it with a multi meter with the meter set on olms it should read close to 0 when it is 32 degrees or lower, if not it needs replaced. you can remove it and use a glass of ice water to check it. the heating element is under the coil and if the meter is attached to both ends should read 0 if it is good if it does not have any reading when attached it needs replaced. if both test good you will need to replace the main control board. hope this helps
How to test a defrost tstat at room temp
Directions for testing a refrigerator defrost thermostat.
Before you begin to test your defrost thermostat, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this repair.
  1. Locate your refrigerator's defrost thermostat. In freezer-on-top models, it may be located under the floor of the unit, or it could be found at the back of the freezer. If you have a side-by-side refrigerator, the defrost thermostat is found at the back of the freezer side. The thermostat is wired in series with the defrost heater, and when the thermostat opens, the heater shuts off. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
  2. The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
  3. There are two wires leading from the thermostat. They are attached to terminals with slip-on connectors. Gently pull on the connectors to release the wires from the terminals. You may need to use needle nosed pliers to help you. Do not pull on the wires themselves.
  4. Proceed to remove the thermostat. It may be secured in place with a screw, clip, or clamp. The thermostat and the clamp on some models are one assembly. On other models, the thermostat clamps around the evaporator tubing. In some other cases, the thermostat is removed by squeezing in on the clip and pulling the thermostat up.
  5. Set your multitester to the R X 1 ohms setting. Place each of the multitester's leads on a thermostat wire. When your thermostat is cold, it should produce a reading of zero on your multitester. If it is warm (anywhere from forty to ninety degrees Fahrenheit), then this test should produce a reading of infinity. If the results you receive from your test differ from the ones presented here, then you will need to replace your defrost thermostat.
Oct 28, 2012 | Refrigerators
How do I access the defrost thermostat for a frigidaire model FRS26ZRF
It's in the freezer section behind the access panel. towards the top of the evaporator. usually at the top of the evaporator clipped to the line.
Mar 21, 2011 | Frigidaire FRS26R4A Side by Side...
Not cooling
If your freezer is not cooling, i will suggest you check the defrost thermostat. To test the defrost thermostat, please follow the steps below:
To replace the defrost thermostat, please follow the steps below:
  5. To install your new defrost thermostat, reverse the removal process. Reconnect the wires, replace the panel, and restore power to your refrigerator. For those models where the defrost thermostat is attached to the evaporator coil, make sure you install the new thermostat in the same location and position of the old one.
Hope this information helped. Thank you for using fixya
Jan 16, 2011 | Thetford Norcold RV Cooler/Freezer
How do I replace a defrost thermostat on a Maytag MBB2256GES?
Good day,
You have to remove the rear panel in the freezer compartment. The thermostat is clipped to the top of the cooling coil. Fairly simple job.
Here is a picture of one style..
May 20, 2010 | Maytag MBB2256GES Bottom Freezer...
Frigidaire frs26znhd1
you have a bad defrost thermostat or defrost heater the way to get to both of these is go inside your freezer section and take off the panel on bottom the defrost t-stat is on top of the coil clipped to the line and the defrost heater goes up under the coil
Sep 29, 2008 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
