Question about Kenmore Elite 45986 Front Load Washer
Error code F 11 how do you fix it
  • pacrat5 Dec 14, 2007
    I've had the same identical problem and will have put in a service call to get a new MCU board.
    Looking at all the F11 and DL complaints -- I'm starting to wonder if this would fall under a manufacturers RECALL? Too many people with the same problem - - coincidence or defect?
  • allmajorappl Jan 17, 2009
    We were getting the DL and F-11 code. Tech sheet led us to examine connectors on mcu board and ccu board. We saw no visible signs of a bad connection so we replaced the mcu board and the lock and latch switch.It ran 1 load and the DL code returned. We discovered that when we pressed on the d-3 connector at the ccu board it would lock and wash with no problem. We assumed we had to have some issue with the wiring harness after we pulled and checked the ccu board for any cracked solder joints or hot spots and we have a new mcu board already.We replaced the wiring harness only to still have the same situation. I guess the next step would have to be the ccu board. I am stumped.
    Bobby/ga.
  • 259 Answers
F11 is a serial communication error. Information between the central control and the motor control cannot be sent correctly. C01 through C08 is just the test sequence: 01=fill by cold water, 02= dispensor motor, 03=fill by hot water, 04=drum rotates clockwise, 05=heater on, drum rotates, 06=drain pump actuated, 07= drum rotates counter clockwise, 08= high spin. You are recieving a fault before the test can complete.
Here is a posting of some one who had the same problem:
I have - since posting the original - tried to remove the serial cable connectors from both ends of the cable and soldering the wire right to the PC boards. It seemed to help, but the F11 returned. I think the temporary help had to do with powering down and up. In fact, I found that if I powered down and let the machine "rest" I could get at least one load out before F11 came back.
I finally bit the bullet and bought a new MCU at around $200. I have a family of 6 and a malfunctioning washer just isn't an option. I replaced it in mid January and haven't had the dreaded F11 since.
I did notice that on the MCU (that I removed) there is a small transformer that must be for the DC power supply to the board. I bet this powers the low voltage inputs/outputs as well as the processor (via some additional regulation). This transformer looked like it has been getting hot. The iron laminations and dielectric of the windings was irregularly blackened in places.
I further speculate that as the transformer gets hot, it starts to sag the DC Voltage of the MCU. The lower DC voltage could cause faults in the processor, faults in the serial comms, any number od problems.
Unfortunately, I feel the ultimate resolution to the problem is to replace the MCU. I do believe that the anti-vibration techniques listed in this thread would be good preventive measures. Vibration is no friend to electronic components hanging on by solder - especially relatively heavy objects like transformers and bigger capacitors.
Posted on Dec 09, 2007
Fisher & Paykel fridge is showing F20 fault in screen and beeps when door is opened
SOLVED: Fisher paykel French door fridge shows F20 error - Fixya
www.fixya.com/support/t16590488-fisher_paykel_french_door_fridge_shows
Feb 15, 2013 - F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires ... What does F20 mean on my F & P Fridge. When I ...
14 Feb 2018
What does F20 mean on my F&P fridge. It beeps ...
14 Feb 2018
I have an f20 error on my fisher and paykel fridge ...
16 Nov 2017
SOLVED: Error code F20 on RF610A Fisher & Paykel
9 May 2011
More results from www.fixya.com
Fisher Paykel Refrigerator F20 Error Code ' Wills Creek Community ...
www.willscreekcommunityforum.com/fisher-paykel-refrigerator-f20-error-code/ Sep 27, 2017 - If you are experiencing a F20 code on your Fisher Paykel refrigerator, you will hear a constant beeping sound when you open the frig door. This error code means there is a broken wire on the top of the door hinge (usually left side). If you are even a bit handy, A simple solder job is the fix and can save you ...
Apr 29, 2018 | Fisher Refrigerators
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
HOW DO I FIX HP DJ T1300 WITH ERROR CODE 08:11
There is a cable behind the disply screen that has a tendency to wiggle loose in shipping. Just reach behind the control panel and push the cables in firmly.
Aug 13, 2014 | Office Equipment & Supplies
Jenn-air jmv8208bas e-11 error code
test this problem and fix it. God bless you
E11 A, F CT oven; latch switch problem
Jul 22, 2013 | Microwave Ovens
Replaced mother board due to error code c2 11 as per rheem tech department. now code 11 flashes after 3 to 4 minutes of use and unit shuts off. WHAT NOW????
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Dec 29, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have an error code of c2 11 on rheem model number ptg-74pvn-2 I will get warm water for about 5 seconds and then it goes cold
www.howtolou.com/clean-a-burner -Lou
Dec 10, 2010 | Rheem Tankless Hot Water Heater...
When i start my fifa 11 then it can't start its writting E0001,what shoul i do?
Lol just change your resolution and then change back....worked for me
Dec 10, 2010 | Computers & Internet
Error code F-46-11 in my photocopier konica minolta 7035
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Feb 04, 2009 | Konica Minolta DiALTA Di200 Copier
Kenmore Elite 45986 Front Load Washer Logo
240 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
