Question about Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC Adapter, none of the usual battery charging lights on the laptop are on. I tried the Power reboot suggested on the ACER site, but to no avail (where it tells you to hold the power button pressed after taking the battery out and disconnecting the power supply).
    Novelist:
  • 110 Answers
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Posted on Sep 08, 2009
Testimonial: "Thanks for the reply! This just confirmed what I had been suspecting looking at other sources on the web. "
  • vermeulec Dec 26, 2010
    Yes.. the mother board is causing it. There is a diode PD8 associated with PR8 resistor and some transistors. My PR8 was burned out and the diode is measuring bad.
    have not repaired yet
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Acer aspire 3610 power lead transformer green light is on before plugging into laptop then goes out when plugged in.acer has nothing working, totaly dead any ideas?
If the power LED is lit before connecting to your laptop and then goes out as soon as you connect to your laptop, then you either have a short circuit in the power supply module of your laptop, or you battery is causing the fault.
Remove the battery and try again. If it powers up the battery needs replacing. If the problem is still the same then you need someone to look at the power supply module in the laptop
Mar 09, 2010 | Acer Aspire 3610 Notebook
Acer Aspire 5920 won't turn on, the charger lights up, (bright green) until you plug it into the back of the laptop, then the light goes dim and flashes.still no power to the laptop,not even the fan.
Your power supply or regulator in you laptop has gone south. sorry no quick fix for this one. It needs repaired and would include tracking down soldered connections.
sorry to tell you this.
clb199@yahoo.com
pls rate me 4 stars
Nov 27, 2009 | Acer Aspire 5920-6727 Notebook
My ACER 5920 will not boot up when the charger is plugged in th
Dear Sir,
By analysing your problem it seems to be your adapter dead.So first check your adapter,so your laptop battery may not have backup to turn on the laptop.
Sep 11, 2009 | Acer Aspire 5920-6727 Notebook
Sir, i have bought a acer laptop model aspire 5920 but when i was working on it suddenly it shut down and till now i cannot made it power on can you tell me the problem
Remove the battery and the power adapter, wait 5 minutes, plug in the power adapter and try turning it on, if it doesn't turn on, remove the power adapter, plug in the battery and try starting up again, if it still doesn't work plug in the power adapter, try starting up.
Is the power adapter working? does it have a green led on it that shows that its powered?
Sep 10, 2009 | Acer Aspire 5920 Notebook PC
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
The exact same thing is happening to mine.
have a computer tech analyze the problem.
Jul 14, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not power up
It sounds like the motherboard has been damaged. Might of been a short circuit some where.
Feb 11, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5920-6727 Notebook Logo
673 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
