Question about IBM Tablets & eReaders
Keyboard key popped off - IBM Tablets & eReaders
    Novelist:
  • 110 Answers
The key should pop back on... if it doesn't then the brackets on the keyboard for that specific key are broken. The keyboard will still function properly... every key will work fine.
Or buy a new keyboard.. they are cheap.
Posted on Sep 08, 2009
P1000 10.1 polaroid tablet. How can I get keyboard to work?
Hi they r cheep to buy on E/BAY APROX $23. THIS WOULD B THE BEST WAY TO FIND OUT IF IT IS THE KEYBOARD OR YOURE TABET THAT IS AT FAULT CHEERS
Mar 07, 2016 | Polaroid Tablets & eReaders
Why aren't detachable keyboard keys a/z/q working?
I can only guess but sounds like you need to buy a new keyboard .
Dec 30, 2015 | Tablets & eReaders
How do I get the keyboard of my Ipad mini to drop down it is stuck at the top of the page and has split in half
In the lower right of the keyboard is a keyboard key (it looks like an icon of the keyboard). Touch and hold the keyboard key. After a second or so, word choices will pop up saying something like "Dock" and "Unspilt". Touch one of the words. If you want to do both actions, repeat the process for the latter.
Feb 19, 2015 | Apple iPad Mini
Dont get any keys on tablet
On a tablet you move ahead by swiping the screen with a finger or with a stylus. If and when you use an app the requires text input, a virtual keyboard will pop up on the tablet's screen.
May 21, 2014 | Samsung Tab Tablets & eReaders
Zeepad tablet instructions
Touching the input field 'box' doesn't open the keyboard?
Feb 06, 2014 | Tablets & eReaders
I need a passcode to connect to my phone and I don't have one
make sure phone is set to discoverable in bluetooth settings and it should give you a passcode for the other device tryin g to connect
May 17, 2013 | USRobotics U.S. Robotics USR5500 Bluetooth...
Changing keyboard on Fujitsu T5010
Remove the square screw covers above the keyboard on either side of the swiveling screen hinge. Unscrew the 2 screws and use a small flat head screw driver to remove the plastic cover above the keyboard. Do this by inserting the screw driver underneath the plastic cover near to the f keys on the keyboard and gently pop the cover off. Carefully remove the ribbon from the motherboard, use a small screw driver to release the clip that holds the ribbon in place (ribbon located above f3,f4 keys). Slide the keyboard up and it should release if it doesn't then there may be some sticky tape holding the keyboard down, this is located behind the f2,f3,f4,f5 keys, carefully pull the keyboard away but hold the keyboard by the f keys so that you do not damage the keyboard by bending it. Reverse the procedure to fit new keyboard
May 28, 2010 | Fujitsu Siemens LifeBook T5010 Tablet PC
Problem .......x61 tablet help !!!!!!!
Hello snapshots,
I have an x61, and you may want to check that all of the keys on your keyboard are not damaged, and that none of them are stuck in the pressed position. That is what the "stuck key" message typically means. If you check out the keyboard, and all the keys are fine, and if you are still receiving this message, try calling Lenovo support. There is an off chance that your keyboard (or other components) may be slightly defective.
Here is the link to the Lenovo site: http://lenovo.com/planetwide/select/selector.html
Hope this helps!
Jeff
Feb 27, 2009 | Lenovo ThinkPad X61 Tablet PC
TC1100 keyboard replacement info
If you are replacing the keyboard component (i.e. the actual keyboard) the process is straightforward. You will need jeweller screwdrivers as the srew (torque and philips are quite small):
1. remove all outside screws on the back of the keyboard
2. as per wkuk above you (thanks!) you will see 4 small covers
3. Pop the covers off with a pin they are lightly glued on
4. Remove the 4 screws (philips head)
5. Turn the keyboard so the keys face the table
6. Separate the case exposing the back of the keyboard
7. There are two screws that need to be removed that hold the keyboard in
8. Remove the tape that holds down the ribbon cables
9. Two ribbon cables attach the the keyboard. Be VERY careful and disconnext the slim one from the existing keyboard. Disconnect the second cable from the keyboard body (as the kew keyboard will plug in there.
10. Remove the keyboard and replace with the new keyboard
11. Reverse the steps above.
The real key is to be careful with the cables. Hold the entire cable firmly as these types of connectors can tear. When you initially slowly remove the cables you will gain some idea of how far the cable goes into the connectors. Although I've done lots of fixes on hardware this was my first time doing my keyboard for my TC1100 and the start to finish was 15-20 minutes. If in doubt, take a phot of the keyboard after you've removed the keyboard.
Cheers,
David
Jun 09, 2008 | Compaq tc1100 Tablet PC
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Jan 16, 2008 | Toshiba Portege M400-S5032X Tablet PC
Tablets & eReaders Logo
233 people viewed this question
Top IBM Tablets & eReaders Experts
Steven Wander
Steven Wander
Matthew Spark
Matthew Spark
Are you an IBM Tablet and eReader Expert? Answer questions, earn points and help others
