The problem is that the Datel drivers for the Action Replay are not signed, and Microsoft decided that as a matter of policy the 64 bit version of Vista would not accept unsigned drivers.
Unless microsoft change this policy, it will not be possible for the AR to work under 64 bit Vista.
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged.
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
With your console powered off insert the Action Replay DS
Hold down buttons A+B
Turn your console on
With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
whats an ard?
from code junkies
I'm not sure if you're asking for cheat codes for use with Ridge Racer DS for the Nintendo DS, or Ridge Racer V for the Playstation 2 - Unfortunately, neither game has actual cheats built into them. You can, however, use a hex editor tool (also referred to as a Trainer, Gameshark, or Action Replay), which would allow you to cheat.
If you bought the action replay, plug in the cord and a screen will pop up asking you if you want to search for NDS drivers. It will then say no drivers can be found but if you have the disc that came with your NDS to insert it into the computer. You put the small disc that came with the action replay into the cd rom and it will detect the driver. Then you can install the driver.
IF you are running Vista 64, the issue is the driver on the disk is incompatible, thus the pc will never see the ds. However, I have found a workaround. First make sure the DS is on and plugged in and the Action replay Manager is launched. On the DS click on the mouse so it should read updating software. Then, go into device Manager via the Control Panel, there you will see NDS and an exclamation mark. Right click and choose to update the driver or properties. Then choose Browse My computer for driver software... then let me pick from a list... then fo the manufacturer shoose: Standard USB Host Controller and for the Model choose Unknown. It will pick it up instantlly. Voila.. Good Luck! and what a pain!! V
