Question about Kenmore 92002 / 92004 Kitchen Range
Inner part of Triple element on 790.9912940 won't turn on
I just experienced the same problem I've been reading about here and on other appliance repair sites: the inner element of my Kenmore Elite's front-right triple element will not turn on, despite the control panel saying it's "on." The range is about 2 years old, just like many other people have said. Also, Sears naturally wants to charge $65 to even come look at the part, and then several hundred more for a new element.
From reading other comments and after talking to Sears, it seems like there is no extra warranty or recall on this part. This triple element is apparently a defective design if I can find so many reports of this exact same issue with only a cursory Google search. Would not have bought Kenmore anyway if it hadn't come with the house, because I've heard of this kind of thing with them far too often, despite their obvious good looks and nifty features... I'd rather not have to spend hundreds of dollars just to keep my $1.2k range working properly - for that price it should have a 5-year warranty at least in my opinion.
I'm going to see about removing the element and putting in a new one on my own, as getting the part itself (Sears Direct Part Number 316216702) is only about double the cost of getting a technician to come out in the first place.
You can see a handy part diagram of the range top at this link, by the way:
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0610001-00003.png
The element that has failed on my range is part 15B in the diagram.
  • 311 Answers
SOURCE: The inner right front element
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Front right (6IN) radiant element went bad
Congrats on your troubleshooting efforts. The element you speak of is called a "dual element". Unfortunately, you can only purchase it as an entire assembly. This is a fairly simple repair that you should be able to perform yourself. Just follow these steps:
First, please review your Warranty Information. Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
I would recommend you have someone assist as this should be a two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with elements turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
3. On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, you can unplug the entire top panel and move it to flat surface to work on it.
If not, you will have to prop the top panel up.
NOTE: If moving the cooktop to another work surface, place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
4. Remove the defective surface element by disconnecting the terminal plug wires. Make sure you label them.
5. Next, locate the two tabs that hold the element in place. Take note of the numbers that the tabs are inserted into. These are alignment marks and you will need to install the new element in the same manner. Take a pair of pliers and slightly bend these tabs by turning them so you can remove the element. NOTE: You may have to remove the bracket guard that holds the element in place. If so, leave the bracket face down when you remove the screws. This leaves the existing good element from being moved around and reduces the risk of damaging it. Lift the bracket up slightly,and slide the defective element out.
6. Remove the old element and discard. Install the new element making sure you handle with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. NOTE: Ensure you use the same alignment marks.
7. With the element installed, lock the tabs in place and install the wire connectors. Reinstall the screws on the bracket guard.
8. Lower the cook top back into place and secure with screws.
If you have questions along the way, please let me know. I hope this helps you.
PS You may experience a bit of smoking when you turn on the new element for the first time. This is normal.
Posted on Jun 29, 2009
RED92JEEPER
  • 51 Answers
SOURCE: I have the same problem with the inner coil.
their is no aftermarket element just oem element as far as the repair manual they have a service manual for it
Posted on Sep 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
  • 417 Answers
SOURCE: My Kenmore 96313402 range keeps tripping the
There are 2 reasons why a breaker trips one is overcurrent i.e. the current flowing thru is greater than its rated capacity or if there is an earthfault causing the same condition. You have to establish which it is.
From what you say it would seem as if the total current exceeds that of the breaker capacity. In which case you can either ensure not all elements are used at the same time or up rate your circuit and breaker.
Posted on Dec 14, 2010
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Oven won t heat up properly
Hello Greg, I am happy to assist you. Let's try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. If you have a gas range, while the unit is turn off; confirm that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. Then you may turn the appliance on. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. The unit could possibly be experiencing a potential wiring failure, faulty EOC (electronic oven control), sensor probe and/or bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Aug 05, 2013 | Frigidaire Kitchen Ranges
Large triple burner on right works on outer burners but inner burner will not come on??
Computer controlled. You need a technician. (I avoid buying appliances like that, like I avoid the plague). God Bless (and long live) the older appliances with knobs and thermostats!
Oct 08, 2012 | Ovens
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
My area recently had a power failure. Oddly, during the power failure I could still see a light coming from the Canon MG5220 printer. After power was restored, it was sometime later when I noticed that...
Unfortunately, it sounds like when the power was restored, the printer experienced a surge. If this was not plugged into a surge protector, then it's possible the switch was fried at the point of power restoration. It is important that with units such as printers, monitors, towers (computer), tv's, vcr/dvd players, almost any type of electrical appliance be plugged into a surge protector. However, even if this was true in this case - when a power shortage (outage) is experienced, it is necessary to unplug everything so that when the power is restored, nothing that is plugged in will be affected; as your printer was.
Now, you can have this fixed - either take it to a local computer repair shop; that might be able to fix it, or contact the manufacturer and inquire about sending the unit in for repair - regardless of warranty or not. If it is still under warranty, they may honor it. I am not positive they will for an accidental damage such as this, but it's worth calling them.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 25, 2011 | Canon Pixma MG5220 InkJet Printer
Sep 24, 2009 | Kenmore Kitchen Ranges
On right front triple burner the inner ring does not come on
if you are correctly turning the knob on to turn on that specific one(some require turning knob opposite direction to turn on that ring, read use and care or owners manual for instruction)
then check switch and element
should be one of these two, rarely wiring harness
May 02, 2008 | Kitchen Ranges
Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Dec 20, 2007 | Kitchen Ranges
Kenmore 92002 / 92004 Kitchen Range Logo
459 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
