Question about Dell Dimension E520 PC Desktop
Speaker have become staticy. Don't get a clear
Speaker have become staticy. Don't get a clear sound anymore
  • print-or-die May 11, 2010
    What speakers... ? Are they built into the monitor, or are they seperate from the PC? Do you have other speakers to try? Do other speakers do the same thing?
  • 5,603 Answers
Try headphones to see if the audio is the problem or the speakers as a first test.
If speakers have gotten wet or filled with dust/dirt could be the problem.
Wet is fatal, replace them.
Posted on Sep 08, 2009
Staticy in one channel
This is a loose connection and it could be the voice coil in the speaker, the terminals on the speaker, the connection at the terminals on the speaker, the wire going to the speaker, the connection at the amp, the internal connection in the amp, the actual parts on the circuit board of the amp, change the speaker connection at the amp
(switch right and left to see if it is outside the amp)
If not then you are looking at the amp being the problem.
Apr 15, 2016 | Car Audio & Video
Right speaker channel doesn't sound clear anymore
If it sounds like static, and the bass really effects the sound it is most likely going to blow.
I would suggest taking it easy on the volume or switching your volume settings so its more on the left speaker than that right, but still with sound coming out the right one. Just so you don't blow it as fast.
Nov 17, 2014 | Audio Players & Recorders
Laptop speakers picking up interference?
The speaker may not be making proper electrical connection to the motherboard.
Reseat the speaker connection to the motherboard.
Jun 04, 2012 | Dell Latitude E6510 Notebook
My kenwood car stereo went very staticy then quit working and it blinks "PROTECT" on the face
One of your speakers has gone bad. When this happens the speaker can become a short in the circuit. This can burn a circuit up. The radio enters protect mode to protect itself. Unplug a speaker one at a time with the radio turned off, turn the radio on, and see if it works, repeat this until it does work. When it does, you have found your bad speaker. It is possible more than one speaker is bad, so go ahead and test each one.
Alternatively, if you have a multimeter, set it to measure resistance and take a reading across the speakers terminals, if a speaker has no resistance, then it is bad, if it has a very large or infinite resistance then it is also bad. A normal car speaker should be somewhere around 2 ohms to 20 ohms, depending on size and make.
May 05, 2011 | Kenwood Car Audio & Video
My 2008 Accent radio was working great last week. We had some bad snow this weekend. I went to turn on the radio on Monday and the radio was staticy and sounded like the speaker in the back was not...
Try checking the coax antenna wire coming out of the back of the radio. The antenna wire use to plug in, and I've had problems with them viberating out.
Jan 26, 2011 | 2008 Hyundai Accent
Speaker sounds very staticy
This is normally due to a bad connection, however it can also be caused by a blown speaker. replace with another speaker to see if the static is still there, if you still hear the static then the speaker is fine and the wire is broken somewhere, is the sound of static goes away then problem solved.
Apr 04, 2010 | 2003 Mitsubishi Eclipse Spyder
AFTER 1 HOUR, SOUND CUTS IN AND OUT, SOUND BECOMES VERY STATICY
ur processor may be going out or ur fan is gone out and units getting hot and cutting in and out check fan firts put a fan behind it blowing on it when u cut it on see if that cures it if it does ur fans probably gone out
Feb 24, 2010 | Televison & Video
Denon 1705 the sound is great and then ever few minutes the sounds goes bad staticy?
check you speaker terminals and make sure the isnt to close to any static clecting devices such as tv, game consoles , and make sure there is nothing on top of the reciever blocking its ventilation
Dec 12, 2009 | Denon Audio Players & Recorders
I output the sound to a Sony receiver. The sound was clear from the sound board, but now is staticy with faint sound. I have updated the driver . . . no change . . . and then restored the default . . ....
Make sure that the output (from sound card) is compatible with input of receiver. Most aux inputs on receivers are 1 volt peak to peak. Turntable and tape inputs are different.
Aug 02, 2009 | HP Pavilion m7100y (PX189AV) PC Desktop
Sounds staticy
unfortunately not.. once a subwoofer is blown its for lack of other words.. dead.
Apr 27, 2009 | Car Audio & Video
Dell Dimension E520 PC Desktop Logo
Alun Cox
