Question about Linksys WRT160N Wireless Router
Have a wpm54g wireless card . The system works just fine until Linksys DualN router turned on then crashes and reboots endlessly. Turn router off and everything is fine. Wireless works on multiple routers but crashes on 2(two) different Linksys Dual N routers.
    Master:
  • 441 Answers
Try resetting the router and then reconfigure it again. or upgrade the firmware.
Posted on Sep 09, 2009
How to reset wireless password on linksys wrt 610n
You can get the manual here
You can reset holding the reset button on the back of the router for 5 seconds, or refer to page 32 of the manual
Nov 03, 2011 | Linksys Simultaneous DualN Band Wireless...
We have windows 7 ultimate on a hp pavilion du 7 laptop, coupled to a linksys wr310n router.It was working fine until our c drive crashed & had to replace , now we can't get the router to work , driver...
For the WRT310n, back to the User Guide (download from Linksys), perform a reset and start over following setup instructions (make sure the router is hardwired to the laptop). Set up a new home network on the laptop using Control Panel. Make sure the adapter settings are correct and good to go. Then see if you can connect to the router with your browser to set it up. After setup, you should be able to connect to the router wirelessly from the laptop, but you have to make sure the wireless transmitter inside the laptop is turned on first (see the laptop user manual).
Jul 05, 2017 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Wireless Router Causes XP PRO to Crash. I just purchase a Linksys WRT110 wireless router and installed it using the EasyLink setup cd. The install went OK but Windows XP PRO immediately crashed and...
Have you unisntalled all the Linksys sofftware through add/remove software. I had a similar problem with an IOGEAR Bluetooth transceiver, I did the setup from the CD, my laptop (Dell C640) blue screened each time. I uninstalled all the IOGEAR software and my laptop stopped blue screening. I never installed the software for a wireless router, I always use the WEB interface and my life is my simplier.
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
my apologies it was a typo...
the command is eventvwr.msc
what you need to do now is install a program called radarsync (google it) AND BE VERY CAREFUL TO UNCHECK THE OPTIONS OF ALL THE TOOLBARS IT WILL ASK YOU TO INSTALL THIS IS VERY IMPORTANT.
ITS A FREEWARE THATS WHY ALL THE TOOLBARS but trust me you dont want them.
let the tool scan for updates for your computer install the update you find for the wireless card and reboot
you shouldnt be getting the problem anymore
please rate if his fixes your issue
thanks
Dec 14, 2008 | Linksys Wireless-G WRT54G Router
"Local Access Only"
You need to look on the back of your router and find the small reset button. Push it and everything should reconfigure. If not Go into your device manager and see if you can find something called a NIC card or Network Interface Card, or something called an Ethernet card, if those are not listed, it means your driver has been deleted somehow. You can go to the manufacturers website and download a new driver.
Sep 22, 2008 | Linksys WRT55AG Router
Linksys routerr
Try to do a complete power cycle on your devices. Turn off router, turn off modem, turn off computer. Wait for 30 seconds then turn on modem first, wait for all the lights to stop blinking then turn on router the reboot computer. Hope that helps
Jul 12, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Cannot get online with Wireless G WRT54G router. Can get online by pressing Cisco Systems button but only temporarily.
Do U see the router signal on the wireless network connection search?
Sometimes the linksys systems cd does not want to work on some pc's. try using the control panel - add/remove programs and uninstall all programs for the linksys. Then goto the control panel - system - hardware and uninstall the linksys card. Leave the actual card installed and reboot. After it detects your card use the linksys cd to load only the driver.
In the properties of the wireless connection, let windows manage it.
The above is based upon the factory defaults of the router. Any keys to access the router would have to be used on the pc.
Jun 02, 2008 | Computers & Internet
Linksys WMP300N Endless Bootup Loop
Disable or uninstall the Linksys software that manages and monitors the connection.
Use instead the Microsoft Windows Wireless configuration utility.
That's what I did and didn't get problem after.
Dec 30, 2007 | Linksys WMP300N Pre-802.11n Wireless...
Router rebooting endlessly, how do I prevent a reset?
Your router is not synchronized with the line. You should power cycle your router (i.e)disconnect power cable from the router waith for 30 seconds and then reconnect, check if the dsl cable is connected properly to the router, if yes remove it once and the reconnect it, this should fix the problem. upgrade the latest firmware version for your router .Are there any electrical devices near the router that are only switched on at that time of day and then switched off again in the morning. What i'm thinking is that you are experiencing REI or Repetitive Electronic Interference. This is caused by EMP emmisions form devices nearby. Have you had anything fitted recently that may be hardwired into you master socket, this will bypass your filter and cause interference on the line. The only other thing I can think of is that there maybe some engineering works going on at the exchange or on the line.
Nov 18, 2007 | NetGear WGT624 Wireless Router
Linksys WRT160N Wireless Router  Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
