Question about Hitachi 51UWX20B 51" Rear Projection Television
Hitachi 51uwx20b Picture appears normal, but there does seem to be a lack of brightness..I can bump it up to about 85-90% and screen get a bit brighter but not overwhelmingly bright..What might be the problem here?
  • 60 Answers
Have you taken off the screen and cleaned the lenses and mirror?
Clean carefully with a dry micro-fiber cloth only - no liquid.
Posted on Sep 09, 2009
I have an Hitachi 53sdx01B rear projection HD TV. Worked great until yesterday when it seemed like the contrast or brightness got out of whack. Whites appear to be overly bright, to the point that...
The tv have picture look like a bright dull hallow glow to the screen,yes,than the tv CRT tubes coolant chemicals is bad.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to do the replacement.
Feb 05, 2011 | Hitachi 53SDX01B 53" Rear Projection...
I had my 51uwx20b tv for 7 great years. for the
needs soldering the bad connections on the convergence board
Nov 17, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Color issues with Hitachi 60V715
You likely have a problem with your Optical Engine. It is very expensive to replace and should fix the problem. The lamp cannot cause color issues. You may have dust/dirt contamination in the engine and it could be clean by a servicer or technical person. The blue LCD panel or polarizer may have failed in the engine giving you blue and yellow (lack of blue) type symptoms.
Dec 06, 2008 | Hitachi Televison & Video
51UWX20B
first check to see if there is any liquid on the board.
if not
then read this toshiba problem and see if yours has the same problem go here
Jan 29, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 51UWX20B 51" Rear Projection Television Logo
123 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
