Question about Amana ACS7270AS Electric Kitchen Range
I've replaced the touch pad 3 times, it's a continuing problem, $200 a pop, I'm going to get rid of the unit---if this is you first touch pad expect to replace anyother on in any 1 to 2 yrs.
  • 867 Answers
I stick to old school dial jobs, no probs, all this fancy stuff just makes problems
Posted on Sep 08, 2009
I keep getting Expected status code(200-209) got 503
  • ios - expected status code in (200-299) got 503 - Stack ... stackoverflow.com/questions/23807162 I got the following error expected status code in (200-299) got 503. I didn't get this all the time. ... RestKit 0.2 Error 'Expected status code in (400-499), got 200'
  • expected status code in (200-299) got 403? ' Yahoo Answers answers.yahoo.com > Computers & Internet > Software > Next
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    • PUBLISHED 2012-12-04
    ... expected status code in (200-299) got 403 what should i do? Add your answer. Source. ... Expected status code (200-299) got 410? Expected error ...
  • ios - Expected status code in (200-299), got 500 - Stack ... stackoverflow.com/questions/21828128
    • LAST UPDATED: 2014-02-17
    • 1 POST
    • FIRST POST: 2014-02-17
    ... NSLocalizedDescription=Expected status code in (200-299), got 500, ... expected status code in (200-299) got 503. 0 SOAP response/Request then how to convert it ...
  • WordPress for iOS Forums » Error: Expected Status code in ... https://ios.forums.wordpress.org/topic/error-expected-status-code... WordPress for iOS Forums » How-to and Troubleshooting. Error: Expected Status code in (200-299), got 503. juangaso Member Aug 22, 2013, 4:29 PM. Hello.
  • expected status code in 200-299 got 500 « My Site My Way ... mysitemyway.com/support/topic/expected-status-code-in-200-299-got-500 expected status code in 200-299 got 500 (32 posts) (3 voices) boldprint Member. I can no longer add posts to my site from my iPhone w/ Wordpress for iOS app since ...
  • Feb 08, 2016 | Apple iPad (16 GB) WiFi Tablet PC
    My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
    check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
    Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
    Replacement screen for meep tablet
    follow this steps and fix it. God bless you
      • 1
        Turn off your tablet and turn the unit over. Use the tip of your small Phillips screwdriver to pop the rubber pads off of the screws on each corner of the rear of the unit.
      • 2
        Remove the four screws from the corners of the back of the tablet.
      • 3
        Insert the tip of your case opener tool in the seam where the front and back halves of the unit meet. Work your way around the sides, popping the internal locking clips as you go. Continue until the two halves separate.
      • 4
        Unplug the screen ribbon which runs from the back of the screen in the front half of the unit to the motherboard located in the back half of the unit. Set the back half of the unit aside and you will see the back of the LCD screen in the front half of the unit.
      • 5
        Remove the LCD screen from the housing and fit a new one in its place. Reverse the steps for reassembly.
    Jul 28, 2013 | Cell Phones
    Can't right or left click on inspirion 1501, touchpad is fine.
    It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
    1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
    2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
    3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
    Sep 21, 2011 | Dell Inspiron 1501 Notebook
    I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
    http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
    The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
    HEPA filter. Depending upon your individual usage (environment and hours used),
    you may need to check and replace the filters more or less frequently.
    To check Expected Filter Life Usage
    When the unit is turned on, quickly press the appropriate filter monitor button. The
    pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
    depending upon how much expected filter life has been used.
    PREFILTER:
    1 flash = from new, up to 1/3 expected life used up
    2 flashes = between 1/3 and 2/3 expected life used up
    3 flashes = between 2/3 and all of expected life used up
    Remains on = time to check/replace pre-filter
    HEPA FILTER:
    1 flash = from new, up to 1/4 expected life used up
    2 flashes = between 1/4 and 1/2 expected life used up
    3 flashes = between 1/2 and 3/4 expected life used up
    4 flashes = between 3/4 and all of expected life used up
    Remains on = time to check/replace HEPA filter
    To RESET Filter Monitor
    When the filter monitor light remains on, it is time to check/replace the filter and reset
    the filter monitor, if needed. With the unit powered on, press and hold the appropriate
    filter monitor button down for approximately 5 seconds until the light turns off.
    Page 6:
    Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
    First machine would come on, do nothing, then go off. Now it does nothing and the door will not even open. Any ideas?
    1. Check that the unit is plugged into a working outlet and for blown fuses. 2. Check for power going to Central Control Unit (CCU) by listening for a click in the CCU when unit is plugged in. If no click, replace CCU. 3. Unplug washer or disconnect power. 4. Check continuity of line cord and line filter. 5. Check harness connections to CCU. 6. Plug in washer or reconnect power. 7. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding.
    Nov 28, 2010 | Kenmore HE2 Plus Front Load Washer
    Scroll is not working
    This could be one or some of the 3 issues that may be happening with your notebook or netbook:
    1) check control panel (if this is windows) and click on touch pad icon and make sure the sofware to control the touch pad is working and it's on.
    2) If it is on, reinstall all touch pad and mouse drivers for this unit by going to the manufature's website and downloading the original drivers for this unit
    3) it that does not work, you may have a defective or broken touch pad and it may need replacing
    BEFORE CONTEMPLATING A NEW TOUCH PAD, do 1 and 2 first.
    They are usually the main causes of touch pad failure and should resolve your issue.
    If both fails you may need to order a new part to replace the pad.
    I hope this helps. Write me back and let me know how it goes
    Jun 14, 2010 | Compaq (153515-001) Touch Pad
    The display at top of stove is showing "F1" and continuously beep
    Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
    or
    F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
    Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
    Cursor Shift
    This could be either a driver glitch or the touch pad is going out, both are common on these models. Start by uninstalling the drivers for the touch pad (some times referred to as the synaptic pointing device), then restart the machine. The machine will find the touch pad and reinstall the drivers automatically. If it's a simple glitch, this will fix it. If it persists, then the pad is failing and will need replaced. The only other thing you might try is to adjust the cursor speed or touch pad sensitivity from the control panel. This will sometimes help to dampen the effect, but usually won't get rid of it entirely.
    Sep 04, 2008 | Dell Latitude C610 Notebook
    Lighting the oven
    Control Lockout (on some models)
    Your control will allow you to lock out the
    touch pads so they cannot be activated when
    touched or cleaning the glass panel.
    To lock the controls:
    Touch the 9 and 0 touch pads at the
    same time for 3 seconds until the
    control beeps twice. The display will
    show LOC continuously and the time
    of day if not blacked out.
    NOTE: All cooking and timing functions will be
    cancelled when locking out the control.
    To unlock the control, touch the
    9 and 0 touch pads at the same time
    for 3 seconds until the control beeps
    twice, and LOC will be removed from
    the display.
    NOTE: Some models have a Control Lockout
    pad. Touch and hold it for 3 seconds to
    lock/unlock.
    Gas/Control Lockout (on some models)
    surface burners, oven burners and control
    panel so they cannot be activated.
    To lock/unlock the controls:
    Turn all surface burners off.
    Touch and hold the Gas/Control
    Lockout pad for 3 seconds until the
    display shows LOC ON.
    To unlock the control, touch and hold the
    Gas/Control Lockout pad for 3 seconds
    until the display shows LOC OFF.
    When this feature is on and the touch pads
    are touched, the control will beep and the
    display will show LOC ON.
     The control lockout mode affects all
    controls. No controls will work when this
    feature is activated.
     The adjustment will be retained in memory
    after a power failure.
    Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Amana ACS7270AS Electric Kitchen Range Logo
    212 people viewed this question
    Top Amana Kitchen Ranges Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Mike Carew
    Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
