Question about Asko Washing Machines
Power light is not turning on. I have replaced the 2 15 amp fuses in the washer (not ASKO fuses) and I have confirmed that the beaker panel is working fine and the dryer which is linked to the washer is working so power seems to be getting to the washer, but no power on light.
  • Asko Master
  • 19,396 Answers
There is need to check if there is power getting at the fuses and power getting to timer control board.That is done reading volts with a multimeter.
For safety reasons I need to remind that all test with live power must be done by a trained repairman.
If there is no power at all and you already replaced the two fuses, then problem can be power cord, internal wiring harness, control assembly .
Posted on Sep 08, 2009
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 | Volvo 850 Cars & Trucks
Power has gone off to the washing machine mid cycle, yet the dryer (which the washer is plugged into) does have power....please help
Welcome to FixYa.
Both the Asko built washer and dryer have internal fuses aside from the home circuit breakers for added safety.
Since the washer is typically plugged into the dryer, you'll want to check all the fuses and wires in both the washer as well as the dryer.
The 2 internal fuses for the Asko washer, (depending on the model, but generally in the same location) are located at the back next to the power cord...
i.e.
To remove and check the fuses you`ll need a flat/slotted screwdriver and place it in the slot of the fuse holder and turn them left 1/4 turn and pull out. (the image may differ from your's as I alluded to based on the model number)
**The above is an image for removing the dryer fuse, but the same procedure applies**
Once removed this is what you should see...
I would also suggest removing the top of the washer to visually inspect the condition of the wires as a poor connection can cause the fuses to blow.
i.e.
The replacement part is a 240v 15 amp slow blow fuse. part number will be as listed below and it is a complete kit available at "repairclinic.com"
# 1460992
Hope that answers your question or better yet solves the problem altogether.
Thanks for choosing FixYa and good luck. Please take a moment to rate the info provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Mar 20, 2011 | Asko Washing Machines
My Asko 20004 washer has been running perfectly since November 1, 1996. On Friday, while washing a load, the washer suddenly stopped. No power, on-off switch did nothing and I checked the house fuses and...
Hello Rick,
Welcome to FixYa.
There are 2 internal fuses for the Asko washer, on the 20004 model they are located at the back next to the power cord...
i.e.
i.e.
# 1460992
Thanks for choosing FixYa and good luck. Please take a moment to rate the info provided and a short testimony if you will its warranted.
Regards,
Macmarkus :)
Oct 17, 2010 | Asko Washing Machines
I cannot ope the door -the wash cycle has not started now I cannot turn the machine on (no red light)
Hi, welcome to Fixya. With Asko machines the issue with the "light" may or may not be related to it not starting as well as the door latch. Sometimes the lens which holds the light in place behind the console cracks and the light falls loose, so although the light still illuminates, you only see a slight glow or not at all as a result. The other issue may be the unit is only getting 1/2 volts. **UNPLUG THE POWER CORD** Check the fuses at the back (there will be 2). They are by the cord in a "holder" that is either gray in color or black. Observe them and you'll notice they have a slot in them so you can use a flat screwdriver to remove the holder/hub (as Asko likes to refer to them), once removed you can check across the fuse with a meter for continuity or replace with a known new/good fuse. If that solves the problem...awesome. Let me know and I'll follow up if needed. **ALSO** If you replace the fuse and in a short time it blows again, you likely need new fuse holders & hubs. They do suffer from metal fatigue over time which in turn causes a poor connection and of course equals undesired resistence, hence...blown fuse. The same can & likely will happen to the dryer if it's an Asko as well FYI. Hope this helps, let me know if I can assist you further. Good Luck. Thanks for visiting "fixya" today, please take a moment to rate the info provided here today. Macmarkus :)
Jun 12, 2010 | Asko W6021 Front Load Washer
Asko W/D. Power to 220 wall outlet and washer
Hello paulehni, welcome to Fixya.
First things first, have you checked the 15amp fuses which are located at the back of your Asko dryer ?
**Turn off your breaker at the home service panel, it should be a 30amp switch**
That is where I`d start and focus your attention. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown. You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, amresupply.com, reliableparts.ca etc. Part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
May 16, 2010 | Asko Dryers
Won't start
Hello, Have you checked the line fuses at the back of the washer ? The Asko washers will have 2x15amp "slo-blow" fuses which screw into a holder via a "hub" which turn's a quarter turn in or out. You will need either a replacement fuse or an ohm meter to confirm or dismiss the fuse or fuses being the problem. What to look for are 2 small gray circular button type things located by the cord with slots in the bottom for a screwdriver or flat blade of some kind to allow easy removal. Let me know how that goes and I'll try to assist you further if needed. Good luck and thank's for coming to "fixya". Please rate this info accordingly to it's helpfulness. Macmarkus :)
Apr 03, 2010 | Asko W6661 Front Load Washer
Asko dryer has no power.Washer ok
By-passed fuses,dealer said he's done hundreds.Saved me a service call.This is the 1st and only problem we've had in 10 years! We love our Asco.
Feb 16, 2010 | Asko Dryers
Light of power button very weak and the start button doesn't work
Hi, the issue with the "light" may or maynot be related. Sometimes the lens which holds the light in place behind the console cracks and the light falss loose, so although the light still aluminates, you only see a slight glow as a result. The other issue may be the unit is only getting 1/2 volts. **UNPLUG THE POWER CORD** Check the fuses at the back (there will be 2). They are by the cord in a "holder" that is either gray in color or black. Observe them and you'll notice they have a slot in them so you can use a flat screwdriver to remove the holder/hub (as Asko likes to refer to them), once removed you can check across the fuse with a meter for continuity or replace with a known new/good fuse. If that solves the problem...awesome. Let me know and I'll follow up if needed. **ALSO** If you replace the fuse and in a short time it blows again, you likely need new fuse holders & hubs. They do suffer from metal fatigue over time which in turn causes a poor connection and of course equals undesired resistence, hence...blown fuse. The same can & likely will happen to the washer if it's an Asko as well FYI. Hope this helps, let me know. I'd appreciate the opportunity to help more if called on. Good Luck
Oct 21, 2009 | Asko T701 Electric Dryer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko Washer
I have a 12505 also. It is a 220VAC unit. There are two fuses that are intended to be accessible from the rear. On our unit, these blow every few years and need to be replaced. The unit shows no signs of life when they go. The fuse holders tend to disintegrate from the heat, so I have had to replace these multiple times also.
Nov 20, 2007 | Washing Machines
Washing Machines Logo
272 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
