Question about Sony Video Game Consoles & Games
My PS3 has the yellow light and doesn't stay on for more than 5 minutes.
  • 3 Answers
YLOD of death can be fixed by reflowing the motherboard....this solves most cases of YLOD....a guy named gilksy did an awesome guide....it is online in pdf format but he also posted videos of the procedure on youtube...so look up Gilksy1 on youtube and watch his videos
Posted on Sep 08, 2009
Testimonial: "Thanks for the help"
Why does my ps3 turn off & wont stay on?
It sounds like you have the beginning of the YLOD or yellow light of death. It's actually an overheating issue.
Aug 09, 2014 | Sony Playstation 3 (PS3) Console
OIL LIGHT STAY ON
DO NOT DRIVE THE CAR w/the oil light on. Verify the oil level. If it doesn't show on the dipstick (ensure it's the OIL dipstick-usually yellow-and not the transmission - usually red). Add 1/2 quart, wait 5 minutes for it to drain, and check until oil is visible on the dipstick.
If it has oil, then your oil pump or oil sensor may be bad. You'll need a mechanic verify which.
Td
Oct 18, 2012 | Cars & Trucks
The playstation will not stay on for more than 5 seconds and a yellow light comes where the green light is supposed to be
Hi there. This is known as the Yellow Light Of Death. It's name says it all. This is an error that occurs with the first Generation PS3's and up till now there aren't exactly a perfect solution. I can give you some tips though.
1. If you still have your warranty, send it back to get it fixed. Most likely they'll give you a new one.
2. In case your warranty is not valid, then the second option is to remove all cables from the PS3, then cover the PS3 is a blanket and then take a blow dryer on low level and gently blow the PS3 through the ventilation area for a few minutes. The heat from the blow dryer will affect the motherboard present and might allow it to work on next boot.BEWARE this might work. The problem has not been fixed unless it is taken apart. I will give you a link to a tutorial made gilksy1 and he disassembles the PS3 completely and then fixes the problem.
Hope this helps.
http://www.zshare.net/download/60176826e38aca42/
Apr 02, 2011 | Sony Playstation 3 (PS3) Console
My ps3 will not stay turned on when i do try to turn it on its light turns to a yellowish color and then starts flashing red like it's off but it stays flashing unless you turn off the switch
The PS3 Yellow Light is the 360's cousin for the Red Ring of Death. My assumption is that you may have unintentionally blocked any sort of cooling the PS3 has. Here are some steps in correcting that yellow light. This information comes from HowtoFixyourPS3.com:
In order to fix your PS3 yellow light error, there are 3 things that you can do.
1 - Restart your Playstation 3.
2 - Check for loose cables.
3 - Unplug all cables, and plug them back in.
4 - Take out your hard-drive, and place it back in your console.
If these 4 tips didn't fix the PS3 yellow light problem, then it's high likely that there's something wrong with your hardware. In order to repair that problem, you can do 2 things. You either send your console over to Sony. Or, you simply fix the problem yourself while using a PS3 repair guide.
Jan 01, 2011 | Video Game Consoles & Games
Ps3 power wont stay on
search yellow light of death on google
1)Turn off your playstation. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work send to sony to get fixed
May 09, 2010 | Sony Playstation 3 (PS3) Console
My ps3 doesnt work and is because of a yellow light!!!
the hardware is done you cut the station off before without waiting
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Will not power up, red light goes green flashes yellow then stays flashing red
Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony and they will send you a new or refurbshed one. Your ps3 is one in a billion (according to Sony). North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
Now you could try doing a few things (hey it's worth a try!)
1. Turn off the switch in the back and wait a few minutes. Turn it back on and try it again. If that doesn't work it may be dead.
2. You could try this article, if you choose to, it's a long shot but might work for you in your case. http://ps3.qj.net/Possible-PS3-flashing-red-light-fix-from-MXACE/pg/49/aid/75721
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will not stay turned on. when i start it. it will run for 8-10sec. then it will reset itself, and then the red light will flash for a minute or two.
yes this is ylod yellow light of death how ever it can be brought back from the dead go to youtube an type in ylod fix and follow gilkeys vid please rate
Aug 29, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problem
the PS3 has a similar problem to the Xbox360...the Red Ring of death,or, in this case, the Yellow light of death. I'm afraid your console may have immolated itself.
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
190 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
