I intend to install more 1 mega of memory, but motherboard not recognized it (one dimm 1gb pc3200 cl3 184-pin dimm). Of origin the PC it has been installing 2 dimms of 512 and I intend to add +1 dimm of 1GB.(what leaves one empty slot).
  • aschauhan11
    aschauhan11 May 11, 2010
    Please specify either the computer model or motherboard make to check the RAM compatibility
    Novelist:
  • 110 Answers
The memory may not be compatible depending on the speed. Try taking out all the memory and just installing the 1Gig stick.. does it work?
If it does then the 1Gig stick is fine, but your PC probably doesn't like you mixing different types and speeds of memory.
If it doesn't work, the 1gig memory module might not be the correct speed your PC wants.
Posted on Sep 08, 2009
What memory do I need?
Your machine has 4 DIMM slots. They use PC3200 (DDR400) DIMMS (184-pin). The machine comes pre-installed with 2, 256MB DIMMS providing 512MB of RAM. The largest DIMMs available in the DDR PC3200 are 1GB. If you keep what you have, you can add an additional 2GB of RAM, for a total of 2.5GB. If you are running WINXP 32-bit, this should be more than acceptable. You can replace all four DIMMS and get 4GB of RAM, but a 32-bit OS can only access a little of 3GB of RAM. If you want to come close to maxing out under a 32-bit OS, remove one of the installed DIMMS and add 3 1GB DIMMS. These are old memory and may be hard to find and actually cost more than newer memory.
Aug 01, 2014 | E-Machines T6212 PC Desktop
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
Dell precision 670. Adding 8 gb total memory. Using Kingston KX1563-NAB; DDR2 2gb 2Rx4 PC3200 EEC, registered. Accepts 4 gb in dimms 1 and 2 (2 gb modules) and boots fine. Adding 4 more gb in dimms 3...
glenn_mullin
From what I can tell the Dell Precision Workstation 670 does support over 4GB of RAM. However when you have over 4GB of RAM installed in the system you have to have the Memory Cooling Shroud connected to keep the memory cool. Also this is only shipped out when the system is ordered with over 4GB of RAM originally. If you do not have this part you can order it from Dell buy calling 877-671-3355.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Dell Precision Workstation 670 PC Desktop
Not recognizing memory.
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory.
In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched,
or you're MB may not see all connected DIMM'S.
See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9).
Example; PC3200 400MHz.
Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported.
Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory.
Mike
May 09, 2010 | ASUS P4S800D-X Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
Computers & Internet Logo
David Payne
David Payne
