Question about Amana Refrigerators
Side by side collects water in the bottom of fridge side
  • 396 Answers
Empty the fridge and check all fans.
Posted on Sep 08, 2009
Water collecting and freezing behind vegetable drawer left side of GBSCOHCXFRWW
blocked drain.
pull the fridge out and look at the back. somewhere (unless it has cover panel) you should see a small hose. this is the drain tube. blow through this and you will most likely feel it clear out a bit. then open the fridge. good chance there could be a bit of a mess to clean up
May 18, 2014 | Refrigerators
There was a puddle of water coming from underneath the refrigerator. what would cause this problem
This is due to condesation water overflowing from the defrost collection tank which is normally located on the bottom of the fridge and above the compressor.
Normally sometimes if the fridge was set to lower temperature the defrosted water will be more than normal. So set the fridge to normal settings and check after draining the tank if the fault recurs.
If so check if the drain pipe from the evaporator collection tray is damaged.
Aug 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The bottom of the freezer is filled with frozen water. Also, there is an occasional water leakage found on the floor at the front side below the freezer door. Do you have any advise on how can I find the...
This can be the drain of the auto defrosted water that is overflowing from the collection tank. This is normally located at the bottom of the fridge and a little above the compressor in some cases.
So you will need to move the fridge forward to check on the bottom side of the back of the fridge.
The water can be drained out of the tank and reset.
Jun 16, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
We have a slow water leak in our fridge. The water pools under the bottom 2 produce drawers.
On most newer fridges, there is a very shallow 'V' shaped collection channel at the back of the fridge just above the bottom drawers, this is for condensate collection. In the middle of this channel there should be a hole, this quite often gets clogged, and over flows, hence the water at the bottom of the produce drawers, clear the hole and it should cure your leak, worth checking every couple of months.
Mar 22, 2011 | Samsung RM255LASH Side by Side...
Where is the drain pan located on the GE Side by Side Refrigerator I have looked everywhere! Thanks in advance for your help.
why are you looking for the pan,you shouldn't have to do anything with it.the pan is at the bottom of the fridge behind the front kick plate and on some models there isn't a pan at all/the water drains to the bottom frame or floor of the fridge where the compressor is in the bottom back,the water collects there and the heat from the compressor and condenser coil evaporates the water.remove the bottom back panel,lok for the drain line or if it just defrosted you'll see the water sitting in the frame.what's happening that you're looking for the pan?
Feb 23, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water on base of the refigerator
find the drain hole and unblock it faily easy on a fridge on the side by side more difficult need to unplug defrost it remuve the bottom panel inside in the freezeer side of the appliance to access the drain tray do nort attemt to remuve the panel while iced up dfrost is must or coud cause serious damage
Nov 13, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Older maytag fridge side by side.
Buk, there's supposed to be a drain pan under your fridge to catch the water that comes from the drain tube. The water that's coming out is supposed to be there (only, it's supposed to be caught by the drain pan)... it's the water that's made when your fridge defrosts itself. If you plug the tube, the water will back up inside the fridge , puddle up in the bottom and eventually leak out through the door.
You should order a drain pan for it. Here's a link to one online. After you have it in place, you won't have to worry about it anymore. The water that collects there will simply evaporate back into the air.
Oct 15, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
44 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
