Question about Intel Pocket Concert MP3 Player
Headset connection A few years ago The connection of the headset had to be re saudered(sp). The connection came loose and as a result the music would come in and out of one ear then it no longer worked at all. I need to do this again and I am trying to figure out how I took it apart without breaking it. Any sugguestions.
4 Suggested Answers
dhruv765
  • 53 Answers
SOURCE: Laptop cannot connect to router with WPA-PSK security
What I believe here is you are not typing in the pass-phrase(wireless password) correctly.
Go to 192.168.1.1 log on to the router ,in wireless section you will find the pass phrase,, create a new one and then try to connect.
Posted on Jun 09, 2008
  • 979 Answers
SOURCE: no sound with a headset
Operating system, please?
Posted on Jun 14, 2008
SOURCE: headset only works in one ear.
For the last year, I have had to pull the cord in a direction that allows for both headsets to function and as of today, now only one headphone works. I was told by Sirius to take my radio to Best Buy or Radio Shack to be repaired. I am going to try using the antenna headphones, so to bybass my broken headphone jack.
Posted on May 19, 2010
Bluetooth conecton faild
You need a new one, the batteries only last a couple of years.
Apr 17, 2012 | Jabra BT3030 Bluetooth Headset
Tip
Switch playing up
I have a H700 , I bought last year and hardly used. I tried to use it few days ago and it keeps loosing connection to my phone. I figured out that the headset switch is very flaky and slight touch makes it connect and disconnect the bluetooth connection to my phone. Any clue to fix it ??
on Jun 19, 2008 | Motorola Mobility H700 Wireless Headset
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
Recently I ordered a Plantronics SP 05 from Ebay. My problem is the headset will not not fit properly into the base. The seller insist that it came this way and now I need some help to figure this out.
There is only 1 headset that's compatible with the SP-05 base. It's the SP-06 (part # 24344-01). Take a look at the following link for a picture.
Replacement Headset SP-06
Good Luck from Headsets Direct!
Jun 21, 2011 | Plantronics SP-05 Professional Headset
Logitech headset problems
the problem is with cable(wire)...the insulation got failed nd got short circuited....if warranty period is there u can get it replaced with a new one...
Apr 05, 2010 | Logitech Premium Headset
My headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Jun 12, 2009 | Cell Phones
Headset is not recognised by Nokia 3500
trhat means that the headset connector is broken
Oct 15, 2008 | Nokia BNIB NOKIA 3500 Classic Unlocked/Sim...
Loose Wire
just open it again u will be all set
Oct 11, 2007 | Logitech Premium Headset
I loose BT connection after one song
Does the motorola headset make decending tones when it disconnects? If it does, you are listening to your music using the Headset bluetooth profile rather than the High quality audio one. You will need to change the way the device is paired to the phone. Try pairing it as bluetooth headphones or bluetooth high quality audio, rather than a bluetooth headset. Once you have done that, you can pair it as a bluetooth headset too, as the motorola headset connects to 2 bluetooth devices, or in this case, one device, with two profiles. To use the headset profile, press the left M symbol once, and the headset will play a sound to indicate connection as a headset. If you press it again, it will revert to High Quality Audio profile, and you can listen to your music, and even skip/pause it!
Apr 26, 2007 | Motorola Mobility HT820 Wireless / Cable...
Intel Pocket Concert MP3 Player Logo
Top Intel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Intel Audio Player and Recorder Expert? Answer questions, earn points and help others
