Question about Northstar Water Heaters
My salt storage tank has water up over the salt approximately 12 inches deep. Is there something I need to do to fix this?
  • 491 Answers
Not necessarily.....monitor the level....if continues to rise,then an adjustment may be required.....many salt tanks have water higher than the salt level at different levels as a normal condition.
Posted on Sep 08, 2009
How many gallons are in a tank 12" in diameter x 40" long?
Radius square x pi = area of circle
6" x 6" x 3.1415 = 113 square inches
113 square inches x 40 inches = 4523 cubic inches
231 cubic inches in 1 gallon
4523 divided by 231 = 19.58 gallon
http://waterheatertimer.org/pdf/Water-heater-Formulas-and-terminology.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 09, 2014 | Water Heaters
How does a home well water system work?
Deep well.
Pressure valve located on front of above-ground-storage-tank will turn pump on-off depending on amount of water pressure inside tank.
When water is consumed inside home, the pressure valve responds to the lower pressure and closes electrical contacts... sending electricity to water well pump located deep underground.
The pump turns on and lifts water through a pipe into the above ground storage tank.
When the tank is full of water, the pressure valve senses the higher pressure and turns off electricity going to pump
Pump shuts off.
There is a one-way check valve on the water line going down to pump, and this keeps water from flowing back down into well.
The above ground tank maintains water pressure for the house.
When pressure is reduced by taking a shower, the pressure valve turns pump on again, and cycle repeats.
Aug 20, 2014 | Water Heaters
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Dec 18, 2013 | Taco 006-B4 1/40 HP Bronze Circulator Pump
I don't have a problem, just a question. I recently purchased a home with a GE Smartwater softening system installed Model GXSF23Z01. What do I need to do to maintain this system. Does it require salt?...
Check the time of day, and make sure it's accuate. Reset if necessary. Add salt if it's low. It's always best to let the salt level run low (about 1-2") so it doesn't mush. Only add 80-100 lbs at a time for best results. This particular softener doesn't keep a water level in the tank, so you won't see any water in the salt area. If there is standing water in the salt area, that could mean it's not working the way it should. Here is a link to the owners manual. It's in PDF format
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003674144.PDF
May 14, 2011 | General Electric GE SmartWater Household...
We have about two feet of water inside the tank area where the salt is. How do we get the water out?
The problem is that the unit is not creating a suction and taking out the brine water. Usually with this model the problem is the rotor and rotor disc seal. It can also be that the nozzle and venturi is clogged. You will need a service call to fix this problem. You can bail it out with a pan, but the problem will return until the service problem is fixed.
May 01, 2011 | General Electric GE SmartWater Household...
Our water softener has stopped working. The salt has turned into one big block. What do I do? Can this be fixed? How?
You are going to have to clean the salt block out of the tank. You can try using the end of a broom handle to try breaking it up. Be careful not to go to bottom of tank. Try pouring a couple gallons of hot water over salt bridge if that does not work and retry. Avoid using pellet salt it causes problems like this. If there is currently water at the bottom of salt tank then system is not working and needs repair.
Hope this helps,
H2O Services
Feb 12, 2011 | General Electric GE SmartWater Household...
I just had a mouse surface in my holding tank how do I clean that out? do I add bleach and cycle the water softener?
The mouse must have been in one of your product bags...depending on the deterioration of the carcus; you may have already injested some of the decomposing material.
1. Turn off the water supply and remove the top cover
2. Make sure you have rubber glvoes. Drain the holding tank and remove and dispose of the remaining salt tablets/product left in the tank.
3. Yes, clean the tank with a disinfectant (bleach) and rinse thoughly. Be sure to rinse the tank...you don't want high levels of bleach in your supply lines.
4. Fill with new/clean softner tablets and return unit to service.
Nov 02, 2009 | General Electric GE SmartWater Household...
Insallation instuction for 29 gallon storage tank
the pressure valve usually has it's own hole,....a pressure valve (relief valve) has a probe that needs to be immersed IN the tank,...get that manual from the supplier (their responsibility), this part not being placed properly can be dangerous! so please don't take any chances,......
Oct 30, 2009 | Stiebel Eltron TEMPRA 12 Tankless Water...
Piping from a rheem 120 gallon water heater to a 120 gallon storage tank
it should be 1 inch and either copper or cpvc pipe with the proper 1 step glue,, what is your question???? what are we to get out of what you wrote???????
Jun 16, 2009 | Water Heaters
Water heater heats but not to same temperature
Try shutting off the gas, shut off the water, and drain the tank to remove any sediment that may interfere with heat transfer from the burner. If that doesn't do it, check the dip tube to make sure it is still intact. The dip tube directs incoming cold water to the bottom of the tank and the hot water is tapped from the top of the tank. If neither of those turn out to be the problem, check the thermo-couple. Since a gas water heater typically survives about 6-9 years, you may be better off just replacing it.
Mar 16, 2009 | Honeywell Water Heaters
Water Heaters Logo
Top Northstar Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Northstar Water Heater Expert? Answer questions, earn points and help others
