Question about Crafts & Hobbies
How to repair chipped bathstone Stone is superficially chipped about 25 X 50 mm above wide window lintol. Should special adhesive be applied before patching and patching with what?
I am not a mason, but do repairs on my own bath stone, I have had advise from a freind who is a mason, and you should only use "Bath stone pre-mix" which costs about £25-£30 per bag(20-25kg), I gotmine from Travis perkins. Alternatively, you can grind up a peice of bath stone, seive it so it is fine, then make a 4:1:1 with bathstone dust:lime:white cement. This will make a mortar that will not be rejected by the stone, and can be worked like normal mortar and also sanded if you catch it at the right moment. Be sure tho, it is a real art form to make it look really good!
Posted on Apr 18, 2010
1 part lime,1part lime and 2 parts kiln dry sand.. No cement. If a small repair then chesil it back about 3-5mm Or bigger build up gradually.. Keep the stone moist to key into. And if the temp is warm,keep straying water,don't let it crack. If you do you've left it to long.build if proud. Then when cured,rub it down... Bm345building@me.com
Posted on Jul 03, 2013
    Sergeant:
  • 384 Answers
I would use epoxy and color it with ground stone dust.
Posted on Sep 09, 2009
My wife was told by our Dr. that she had a 2cm gull stone how big is this compared to mm.
Hi Chris:
There are 10 mm in 1 cm, so the stone is 20 mm.
I'm assuming this is in diameter which is the common way to refer to the size of spherical objects.
20 mm is about .3/4 of an inch, roughly the width of my thumbnail, so the stone would be about the size of a marble that would cover your (or my) thumbnail
May 13, 2015 | Office Equipment & Supplies
Tip
How to Remove Adhesive and Ink with Green Chemicals
Adhesive & Ink Remover was engineered to remove: adhesives, glues, tar, water seal compounds, non-curing adhesive films, inks and grease. The green cleaning products and ingredients are safe for use on metals, plastic, stone, fabric and more. The formulation can also be applied to specialized surfaces, including vehicle exteriors and interiors, Plexiglas, marble and vinyl.
The new green cleaning products employ a microscopic technology to break the carbon bonds that hold inks and adhesives together. The resulting solution disperses in water for easy removal.
This formulation employs green cleaning products engineered from soy and plant ingredients that generate no hazardous fumes. On the institutional hazards rating diamond, the product produces zeros in all four quadrants, including health, reactivity and flammability. The bio-safe ingredients are documented to degrade in a matter of weeks, as described in evaluations by a noted testing laboratory.
on Aug 03, 2010 | Home
Tip
Save even more money! I did this repair for under $20. Instead of replacing the...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on May 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Car wind screen got a stone pitch, any chance to fix it ?
Yes Do an Internet search for "Chip" repair. Your comprehensive car insurance covers most of these type of repairs.
A plastic resin is put on the window, then either heated or chemically cured. Many times these repairs are done in Parking lots by Franchise owners.
May 31, 2012 | Cars & Trucks
The brackets that attach to the driver's window on my son's 2003 Grand Am have broken due to forcing a frozen window. The window is no longer attached to the slide mechanisms. I am wondering...
Hello, normally just the window sashes break. this is the plastic part that is glued on the bottom of the glass. you can but these asahes at your dealer. they simply just glue on with a special glue
Sash Channel Came Off Glass; Adhesive on Glass
  1. Remove the door glass and lay it on a protected table.
  2. Mark the location of the clip with tape.
  3. Remove the adhesive with a one edge razor blade.
  4. Clean the glass with Isopropyl alcohol.
  5. Important: Install adhesive into the applicator and squeeze some adhesive out before you install the mixing tube. After the mixing tube is installed, run a test bead the length of the mixing tube to ensure a good mix.
  6. Fill the sash channel clip with adhesive.
  7. Install the clip in the marked location.
  8. Reinstall the door glass and put the glass in the full up position for 24 hours.
Cut off the bottom edge of the guide with a cut off wheel. (Refer to the illustration above.)
Using a thin flat blade putty knife and a hammer, carefully remove the plastic piece on each side of the glass. (Refer to the illustration above).
  • Clean any adhesive from the glass using a one-edge razor blade. (Refer to the illustration above).
  • Clean the glass with Isopropyl alcohol.
  • Important: Install adhesive into the applicator and squeeze some adhesive out before you install the mixing tube. After the mixing tube is installed, run a test bead the length of the mixing tube to ensure a good mix.
  • Fill the sash channel clip with adhesive.
  • Install the clip in the marked location.
  • Reinstall the door glass and put the glass in the full up position for 24 hours.
  • 22689012
    Sash, Side Door Window
    12378568 (US)
    88901676 (Canada)
    Structural Urethane Installation Adhesive
    Jun 06, 2011 | 2003 Pontiac Grand Am
    Need instuctions for dymo label point 250
    LBrown18062@hotmail.com. My manual is 12 pages long. Please put DYMO Manual as the subject and I will email it to you right away. Waiting for your response.
    About Your New Labelmaker. With your new DYMO LabelPOINT™ 250
    labelmaker, you can create a wide variety of high quality, self-adhesive labels. You can choose to
    print your labels in many different sizes and styles. The labelmaker uses DYMO D1 tape cassettes in
    widths of 6 mm (1/4"), 9 mm (3/8"), and 12 mm (1/2"). Tape cassettes are also available in a wide
    range of colors.
    Getting Started
    Follow the instructions in this section to print your first label.
    Connecting the Power
    The labelmaker is powered by standard batteries or an AC power adapter. To save power, the
    labelmaker will automatically turn off after two minutes of inactivity.
    Inserting the Batteries
    The labelmaker uses six 1,5V AA batteries.
    To insert the batteries
    1. Remove the battery compartment cover. See
    Figure 2.
    Jan 20, 2011 | Office Equipment & Supplies
    What is the solution to fixing small chips in my new granite countertop? The granite countertop was just installed a month ago and the company has not not responded to my letter about the chips in the...
    Try using super glue, the thinner the better the adhesion. Once it is dry hold a single edge razor blade (use extreme caution, razors by nature are very sharp) perpendicular to the surface of the stone and scrape the glue flush, changing blades regularly. Do not use the blade to cut, as it will dig in and pull glue and possibly stone out, as you have discovered. Just take your time and scrape the glue until it is flush with the granite. If the spots are dull, you can use a little carnuba wax (automotive/hardware store) to shine it up. Some types of granite have more texture due to differences in the makeup of the stone which also gives the variety of color. I have filled entire countertops with this method, and it is tedious, but yields good results.
    Feel free to contact me with any questions. Brandon Wiese
    Dec 26, 2010 | Stone TOP ONLY: 21 in Black Granite Vanity...
    97 fxdl, difference between narrow/wide glide componants
    You need the complete front end including the wheel. The FXDWG is somewhat of an oddball in that a lot of parts fit only that bike. A lot of other parts will not fit a Wide Glide. This even applies to the exhaust system.
    Measure the diameter of your upper fork tubes, they're 39 mm tubes. The Wide Glide uses 41 mm tubes. The Wide Glide also uses a 21" front wheel.
    Nov 08, 2009 | Harley Davidson FXDL Dyna Low Rider...
    R/H rear quarter window repalcement
    tv is the wrong adhesive. you must use urethane with a primer. it is available at any QUALITY parts store (NAPA or Carquest comes to mind)
    Material Item Specification Urethane Metal Primer Essex U-413
    WSB-M2G234-C Urethane Glass Prep Essex U-401
    WSB-M5B280-C Urethane Glass Primer Essex U-402
    WSB-M2G314-B Urethane Adhesive Essex 400-HV
    WSB-M2G316
    Removal
    All vehicles
    ani_caut.gif WARNING: To prevent glass splinters from entering the eyes or cutting the hands, wear safety glasses and heavy gloves when cutting the glass from the vehicle.
    1. Remove the C-pillar trim panels. For additional information, refer to Section 501-05.
    3-Door, 5-Door
    1. ani_caut.gif CAUTION: Make sure the cutting blades are changed where the cutting depth changes to avoid damage to the body and trim panels.
      NOTE: Some resistance may be encountered when cutting through the glass locating pegs in the lower corners of the glass.
      NOTE: Lubricate the existing urethane adhesive with water to aid the special tool while cutting.
      Using the special tool, place the flat side of the knife against the quarter glass window. Start at the top and work towards the corners cutting to the given maximum depths:
      1. 20 mm
      1. 60 mm
      1. 75 mm
      1. 90 mm
    Wagon
      NOTE: Some resistance may be encountered when cutting through the glass locating pegs in the upper right and lower left corners of the glass.
      1. 20 mm
      1. 30 mm
      1. 50 mm
      1. 40 mm
    4-Door
      1. 20 mm
      1. 25 mm
      1. 45 mm
      1. 50 mm
      1. 55 mm
      1. 70 mm
      1. 150 mm
    All vehicles
    1. Remove the rear quarter window glass.
    1. Using a soft brush or vacuum, remove any dirt or foreign material from the pinch weld.
    Installation
    ani_caut.gif CAUTION: When installing urethane installed glass parts, the vehicle must not be driven until the urethane adhesive has cured. At temperatures above 21°C (70°F) and relative humidities above 50%, adequate cure time is typically 24 hours. (Refer to Essex drive away chart for the cure times as temperatures and humidity vary.) Inadequate or incorrect curing can adversely affect the retention of the quarter window glass.
    1. NOTE: Avoid scratching the pinch weld.
      Trim the remaining urethane adhesive. The urethane adhesive must be smooth and free of cuts and contamination after trimming. Avoid touching the urethane adhesive after preparation.
    1. Apply the urethane metal primer to any exposed or damaged metal on the pinch weld.
    1. If reinstalling the original rear quarter window glass, remove the excess urethane adhesive.
    1. Clean the rear quarter window glass with a non-alcohol based window cleaner.
    1. ani_caut.gif CAUTION: Wipe off the urethane glass prep immediately after each application because it flash dries.
      If installing a new rear quarter window glass, apply urethane glass prep twice around the glass surface to be urethaned.
    1. If installing a new rear quarter window glass, apply urethane glass primer to the same area that was prepped in the previous step. Allow 5 minutes to dry.
    1. Cut the urethane adhesive applicator tip to specification.
    1. Apply a bead of urethane adhesive on top of the existing urethane bead on the pinch weld. Make sure that all gaps in the urethane adhesive are smoothed into one continuous bead.
    1. Position the rear quarter window glass to the flange, and press the retaining tabs into the flange to engage.
    1. Install the rear quarter window glass.
    1. Check the rear quarter window glass installation for air or water leaks through the urethane seal.
    1. Install the C-pillar trim panels. For additional information, refer to Section 501-05.
    May 29, 2009 | 2004 Ford Focus
    Crafts & Hobbies Logo
    1,691 people viewed this question
    Top Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Debbie
    Are you a Craft and Hobby Expert? Answer questions, earn points and help others
