Question about Samsung SYNC SGH-A707 Cellular Phone
How do I replace the "flip" part (faceplate, inner and outer screens) on a Samsung Sync? The outside screen is dead, inside one works fine.
I have 2 LG env Touch phones and one has a broken outer screen and one has a broken inner screen. Can I combine them into 1 working phone? Any instructions available?
no you can't. Even though the screens are inside/outside, it is actually one conjoined screen. The whole screen needs replaced.
Oct 08, 2010 | LG enV Touch VX11000 Cell Phone
V3 outer screen
There's a tiny magnet in the top of the flip, near the hinge.. try taking a small magnet and hold it over the keypad near the hinge, and see if it doesn't think it's closed, if that magnet didn't get put back in the flip, then the phone won't know it's closed.
good luck!
Oct 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
My blackberry pearl flip 8220 cellular phone not working
hello,it is a flex problem that mainly occurs to flip phones as a result of various opening and closing of the flip.all you need to get is a new flex to fix up the faulty one.you can kindly take it to an authorized expert to fix it up for you if you are not electronically inclined.and also it could be a affect the inner screen soonest if not attended to immediately.it could also be that the outer screen is bad so after the flex is replaced if the screen still does the same then you will need to fix up the screen.
please kindly rate this solution if it's helpful,
take care.
Jun 16, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
The Outer screen is blank (drak)
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
May 10, 2010 | Nokia E90 Smartphone
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Broken Screens the inside one and the outsid one
Toshiba or any Toshiba parts distributor. Do a goole search. The outer is called the Lenticular screen and the inner is the fresnal screen. Not hard to change.
Nov 17, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Bug in screen
It is unlikely the bug got between the inner Fresnel lens and the outer cylindrical disperser lens of this DLP as the separation is minimal and blocked off all around. Much more likely is that is inside the Fresnel lens and may be cleared off with a clean microfiber cloth through a port to be found on each side (guessing) of the set. Try not to add dust. You can also go to avsforum <http://www.avsforum.com/> and search for Samsung HL-P6163 or similar 5-year old. -Ken
Jul 30, 2009 | Samsung HL-P6163W 61" TV
Why in thw world did my screens just stop working?
This EXACT same problem happened to me and I had to pay $50 to some cell-phone repair guy to replace the whole front piece of the phone....I HATE Kyocera and will NEVER buy ANYTHING from them ever again!
Feb 08, 2009 | Kyocera Strobe K612B Cellular Phone
Screen(s) on phone all white/black
yes my friend it does sound like you have cracked the screen. see if you can see any teltale signs where the screen will look as if it has ink leaking if so then screen wil ned replacing. new one can be bought on ebay shop is
4onesrexpres-07802458019
Dec 02, 2008 | Cell Phones
Dead Buttons
i had the same proplem, inside buttons not working, took unit appart (quite easy). you just need to remember where all the little screws go back into. i need that cable though!! thanx for the part number!! c ya
Apr 09, 2007 | Sony CDX-M8805X CD Player
Samsung SYNC SGH-A707 Cellular Phone Logo
65 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
