Question about Lexmark X73 All-In-One InkJet Printer
The copy paper when inserted on the feeder tray is okay until I try to print. A page inserts into the printer and abrubtly stops making a stuttering sound and does not process through the printer. The printer goes into a jam mode. It's not jammed. Can you help?
    Problem Solver:
  • 14 Answers
Your gears are out of alignment or they are stripped out . Check to see if anything is inside to stop paper and create jam. It is a hardware problem and if you can find it by checking its not worth fixing.Cheap printer and it causes a lot of problems. not worth spending a lot of time on.
Posted on Sep 08, 2009
How do I copy from document feeder?
Dear Flaim
pl. do load documents on the adf tray.face upward and the press copy or start. it will do
thanks.
Apr 02, 2015 | HP Officejet 5740 Wireless e-All-in-One...
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
When you send something to print it stops, the attention light blinks red and once you click on the green CHECK button it prints again. Why does it act like its jamming?
  1. Slide the paper-width guide to its widest position, and then pull out the paper tray extender. Figure 2: Move the paper guidesc00648140.gif
  2. Insert plain white paper into the input tray with the short edge forward and the print side down. Slide the paper forward until it stops. Figure 3: Insert paper into the productc00636180.gif
    CAUTION: Make sure the product is idle and silent when you load paper into the input tray. If the product is servicing the print cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. You could push the paper too far forward, causing the product to eject blank pages.
  3. Slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Adjust the paper guidesc00636178.gif
    NOTE: Do not overload the input tray; make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
Nov 09, 2010 | HP LaserJet P3005n Printer
Brother 7340 wont print on envelope just keeps getting stuck, tried opennig the back like the book says but still gets stuck
Are you trying to print from the main paper tray with the envelope or from the auxiliary single page feeder? The auxiliary insert should be directly under the "Brother" logo on the front of the printer. Insert the envelope there. If it's a standard light weight envelope and it gets stuck still then I'd suggest there is a paper jam somewhere or possibly the fuser is going bad.
Oct 29, 2010 | Brother MFC-7340 All-In-One Laser Printer
Paper in tray won't load
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP Photosmart C5180 All-In-One InkJet...
How do i install ink cartridge for HP 4355?
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | HP Office Equipment & Supplies
Feed 1 paper at a tym
try freeing up the paper before you insert it into the printer. an easy way to do this so to "fan" the paper by holding one end and letting each paper on the other end be released one by one.
another thing is that you may be inserting the paper too much inside the paper tray. try inserting the paper slowly and stop at the first slightest notch you feel
Apr 23, 2009 | Epson Stylus CX5400 All-In-One InkJet...
I have a HP OfficeJet 6210 all-in-one printer...whenever I make a copy by inserting sheet into feeder a long black line appears on the page. It is as if there were a long black line on the original. This...
I have the same printer and have the same problem. I found out though that sometimes this works: when you make a copy, select the best quality option. Again this only works sometimes.
Dec 26, 2008 | HP OfficeJet 6210 All-In-One InkJet...
No paper error
There's a little plastice lever type thing that hangs down above where the paper tray is inserted. When the paper tray pops up after being inserted, the paper moves this lever up. This is how the printer knows if there is paper or not. With the tray out, push the little white lever up and see if the "No Paper" message goes away. If it does go away, the lever/sensor is working OK, if not the lever sensor is bad. If that was not the problem, check that the paper tray is popping up after being inserted (look from the back of the device while you insert the tray). If it does not pop up, there is a little white plastic button type thingy on the side of the tray that releases the paper tray to pop up after you insert it into the printer. Make sure that is working correctly. If you flip the pritner upside down, you can see this little white plastic button type thing that should release the paper tray to pop up during the insertion process.
Oct 09, 2007 | Dell 1600n All-In-One Laser Printer
Lexmark X73 All-In-One InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
