Question about Tomtom One Europe v2 GPS Receiver
Switch on problem
When i switch my tomtom on i get the tomtom logo and drums then switches of battery is fully charged
    Scholar:
  • 143 Answers
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Posted on Dec 16, 2007
Tom tom dead
Usually, the device will not switch on because the battery is low, or not charged. If this is the case, charge the battery (fully) first, then try it again.
If your battery is fully charged, and/or the device is still connected to a power source, and it still doesn't start up, try to do a hard "RESET" ... by inserting a pin (or a straightened out paper clip) into the reset hole at the bottom of the device, and pushing it in (gently). Then try to restart it again.
If that still won't start the device, either the software is "bad" or the hardware is "dead". You may wish to send it to TomTom for repair, or abandon it.
Mar 04, 2014 | Tomtom XL IQ Routes GPS Receiver
TomTom GPS 1xl on/off switch does not work When I press On/OFF switch, it does now start. When I put for charging, LEG glows.
leave the device to fully charge then try it , if the internal battery is flat you wont be able to do anything untill you put power to the device
Mar 09, 2010 | GPS
My tomtom go 710 4v00 will not switch on
Fix it yourself, you need either a new battery and or motherboard. Relativly easy to do! 10 small torx screws for motherboard and 2 ribbons, then a few more screws and loosen the harddrive and screen for battery
Battey and motherboard for less than £50 pounds off ebay
Aug 09, 2009 | Tomtom GO 700 GPS Receiver
TomTom Go 910 comes on, then goes off
Sounds like a dying battery. There is not enough charge being maintained in the battery to complete the loading of the data. ChaNGE THE BATTERY
Jul 20, 2009 | Tomtom GO 910 GPS Receiver
Tom tom will not switch on
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom 720 standby
What you report is very very common. It's also common with other electronic stuff with similar type batteries. I ahve a portable DVD that charges OK 100% and will run for hours after a full charge but If I( charge it , then leave it for a day , the battery has gone flat or nearly flat . Doesnt present any problem or appear to do harm to the battery as it's been like this for about 2 years now. It's just inconvenient , thats all.
My Tomtom is the same , so I did a little modification . I used a read switch ( very tiny ) and broke into the battery cable inside the tomtom and connected the 2 resulting ends to the read switch then positioned the read switch at the back of the tomtom so it would be near to the tomtom mount when affixed . I then glued a small magnet onto the tomtom mount. The result is : The battery inside the tomtom is made disconnected when the read switch opens and it opens when its taken off the mount because it needs the magnet to be closed. ie . the read switch closed when a magnet is put near it and opens when a magnet is removed ( read switch is magneticly operated ). So now my battery doesnt drain as it has no connection to it to drain through. The tomtom will only switch on when its slotted onto it's mount . good luck.
Oct 26, 2008 | Tomtom GO 700 GPS Receiver
My tomtom go 910 will not switch on it has the green light on at the top left when plugged into a charger but nothing turns on when pressing button for 2 seconds any ideas??
In general I find these sort of problems can be fixed by the below
If the Tomtom loses battery power it might cease to function with a blank screen but will show a green light when you charge it. The trick is charge it on the mains charger for at least two hours. Then reset the device with a paper clip. If you get no reponse hold down the on button for at least 20 secs and the device will show the Tomtom logo and play a drum roll and startup normally.
Sep 03, 2008 | Tomtom GO 910
TomTom ONE
Look at the manual or online manual and do a master reset. It will reboot the system and if it can come back on it will. You may have to download the updated software again.
Jun 26, 2008 | Tomtom ONE GPS Receiver
Re battery life??
the battery should last 3/4 hours without a charger.
I think tomtom are aware of a ton of units with faulty batteries / poor life span.
arrange for it to be returned asap.
Dec 04, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
