Question about Etymotic Research Isolator ER-6i Consumer Headphones
Left ear wont play a sound. will try to replace the jack.
Anyone knows the wiring components for the plug? and will it make in difference in the sound if i replace the jack or the er-6i?
    President:
  • 1,137 Answers
Look at this link to see if you want to try it:http://www.metacafe.com/watch/906927/headphone_repair/
Posted on Sep 11, 2009
After doing a reset, the picture dont show up, i can only ear the sound
check your connections try a different hdmi cord or port or try rca jacks you wont have hd if you use rca jacks but you will know if its a conection problem or a problem in the tv
Dec 21, 2012 | Televison & Video
It only lets me listen to music in one ear
  • If you have a warranty I would definitely send it back to the manufacturer. Most companies will pay for shipping for warranty repairs as well. What sounds like has happened happens a lot. The plug the jack plugs into (inside the Mp3 player) gets a cold soldier joint or the jack on the ear buds gets caught on something one to many times and breaks a soldier joint loose.
  • I usually open the media players and reheat the soldier joints myself. If you have already tried a different pair of ear buds it is almost certainly the jack inside the MP3.
  • Hope this helps.
Nov 08, 2011 | Nextar MA797 MP3 Player
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
Phasing,The headphones sound as if they are phasing and only playing Hi end frequencies.
If they sound tinny or spaced out you could have a faulty earth connection on the wire or in the jack plug.
For a solution see my tip on replacing jacks and cables on headphones.
Apr 16, 2010 | Bose on-ear TriPort Headphones
Bose on ear headphones
replace the jack,
cut the wire from the jack then replace it with new one.
remember that the
Tip - Left
Ring - Right
Sleeve - Ground
Jan 11, 2010 | Bose TriPort Consumer Headphones
IPhone 3GS: suddenly music only on the left
hi. i can help you. begin by cleaning out the little hole your ear buds plug into. Carefully clean the jack hole with a needle or a tough pick. It allowed me to remove a lot of cotton like dust. if that doesnt solve it go into your phone menu under audio settings and see if you have adjusted the balance to cause your problem.
also, You can try removing any debris that might be in the headphone jack by plugging and unplugging the headphones a few times.
If the issue is not caused by debris in the headphone jack, request repair/replacement of the Apple Earphones with Mic online here: https://selfsolve.apple.com/GetWarranty.do
You can also request service by making a reservation with a Genius here: http://www.apple.com/retail/geniusbar/or call AppleCare U.S. iPhone technical support at: 1-800-MY-IPHONE (1-800-694-7466)
Nov 10, 2009 | Apple iPhone 3G
Loose Wire, please help
You will have to buy a replace ment jack and solder the connections. These cords seem to have different colors between manufacturers but start by soldering the green or blue (left) to the tip of the plug, the next ring to the red(right) wire and the base to the copper(ground) wire. Try to get a plug with a metal shield that unscrews and make sure you thread the cable through the shield right way around( threads towards plug before you solder.
Apr 21, 2009 | Skull Candy Lowrider Headphones
Fixed broken headphones but sound quality has plummeted
 it sounds as if the wires are wired wrong . yes it is best to solder the wires.all jacks are the same,yours will be stereo i believe. is the braid attached to the earth point, the two other wires attach to the centre of the plug and the other terminal point. these are right and left.
Mar 10, 2009 | Bose Around-Ear Headphones - Silver
No sound out of one of the earbuds
YOU HAVE A STEREO JACK, LOOKING AT THE EAR JACK THERE ARE 2 COLORED CIRCLES AROUND THE STEEL EAR JACK WHICH DESIGNATE STEREO, ONE COLORED CIRCLE IS MONO-ONE SIDE, IF YOU HAVE TRIED SEVERAL DIFFERENT SETS THEN YOUR EAR JACK IS NOT MAKING A GOOD CONNECTION TO YOUR STEREO EAR JACK AND ONLY GIVING YOU SOUND TO ONE SIDE(MONO), AND MIGHT NEED REPAIRED
Feb 20, 2009 | SanDisk Sansa e260 MP3 Player
My ilo tv wont hook up to my playstation on any channels.
Try plugging into the Component Two jacks (down along the left side). I couldn't figure out mine either, so was resorting to unplugging and plugging in the game when I wanted to play. I had the DVD in those jacks originally. Now the TV is stuck, not responding to either the remote or it's own buttons (except off and on), so we are switching 3 different types of entertainment in the same jacks. It'll work for the time being.
Dec 02, 2008 | iLO 2600 Television
Etymotic Research Isolator  ER-6i Consumer Headphones Logo
306 people viewed this question
Top Etymotic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Etymotic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
