Question about Intel Server Board SE7505VB2 Motherboard
Disk boot failure
My hard disk is working, the system can recognize my drvice but the problem is I can see the drive letter of it on my computer
  • Anonymous Feb 18, 2008
    you have a harddisk ditection
  • 259 Answers
Not sure if your windows operation system is working. If so here are the instructions. Otherwise you can boot from cd (XP) and format the drive.
To access the disk management tool right click on My Computer and select Manage from the menu. There will appear a window with 3 categories in the left: System Tools, Storage and Services and applications. By selecting Storage, the menu will expand and from the dropped down list choose Disk Management, which is the purpose of this tutorial. In the right panel of the window there are shown the disks with partitions, as well as the CD-ROM / DVD-ROM drives.
Initialize new disks
New disks appear as Not Initialized. Before you can use a disk, you must first initialize it. If you start Disk Management after adding a disk, the Initialize Disk Wizard will appear, so you can initialize the disk.
So, right-click the disk you want to initialize, and then click Initialize Disk; in the Initialize Disk dialog box, select the disk(s) to initialize.
Posted on Dec 17, 2007
After installing a new hard drive in my desktop computer, it still does not work. It says no boot device available. Sata's 0 & 1 installed but 2 & 3 uninstalled
No boot device available means the boot device hard drive on your system has no bootable operating system installed on it, or it is faulty. In the BIOS setup program, does the computer recognize the hard drive you installed, and is it included in the boot device list? If you installed a new hard drive because of a failure of the C: drive, the new hard disk does not come with an operating system. You have to install that on the new hard drive from the manufacturer's system restore disks. SATA channels 1 and 2 are just the connections on the motherboard for devices, and usually have a hard drive on one connection and a cd rom drive on the other. Giving the model and manufacturer of your computer might provide more clues.
Feb 04, 2017 | Hard Computers & Internet
Hard disk not recognized by computer hd400ld
Check connectors. Check if you installed hard disk correctly (master / slave option on the disk itself). Check BIOS if the drive is recognized. Start computer up with a valid system on a disk. Start up a disk Partition Manager. Assign a drive letter to your new drive. If necessary create partitions and format as NTFS or FAT32.
Sep 14, 2012 | Samsung SpinPoint T133 HD400LJ 400 GB SATA...
Disk boot failure
Yes, this is have drive issue. May not be fixable with the restore disk. Test your hard drive to see if it's still in working order.
May 21, 2010 | Microsoft Windows XP Media Center Edition...
My computer no longer recognizes the Maxtor one
Windows may be recognizing the drive but not assigning a drive letter for some reason. you may need to go to disk management2_bing.gif and look for the drive there.
to do so go to control panel/administrative tools/computer management
once computer management is up find disk management, inside you will find all the drives that are connected to your computer, you should find your drive, If you do not then the drive may be bad or you are having usb issues.
If the drive is there but does not have a drive letter assigned to it, this may be because another drive has taken the letter normally assigned to it, you will need to right click on it and say "assign drive letter"
Let me know if this helps.
Mar 17, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
How to format only C: Drive( in NTFS) in 160 GB Hard disk
It sounds like you are booting into DOS. Dos is an old system which does not recognize NTFS partitions, only FAT/FAT32.
What you need to do is use Hiren's Boot CD (download off google).
Use it to boot and use the NTFS4Dos utility first. Then start Dos:
Or once you boot into Dos mode with the CD, type:
A:\>NTFS4DOS
.............it will list harddrive partition letters.........
A:\>C:
The above may look different as A:\> can be any drive the cd assigns. C: is also an example as you will see your drive letter in the list of harddrive partitions detected.
If you need more laptop computer repair help please visit our Tech Tips page at http://www.laptopmart.ca
Mar 09, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard disk problem
Better to check if your Hard Disk have a power. By knowing that it is working you have to go BIOS and see it there that it is recognize as Primary or Secondary Setup. Boot Failure have the options why it won't run from the hard drive. #1 Maybe its not detected in your PC or no power, check again inside your CPU if it is properly connect. #2 No windows or any system available. #3 If all of this are not then your Hard Drive are defective.
That's is my analysis on your problem. Hope this might help you to know what is that problem for.
Aug 05, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Problem with recognizing 2nd hard drive in Compaq EVO D510
you need to initialize the newly added drive in disk management, then format the drive once disk management assigns a drive letter.
CONTROL PANEL, ADMIINSTRATIVE TOOLS, COMPUTER MANAGEMENT, DISK MANAGEMENT
There you should be able to see the 2nd drive, Right click and INITALISE it, once it is initialized, it will be assigned a drive letter and you can format the drive
Feb 05, 2009 | HP Compaq Evo D510 e-PC PC Desktop
It recognizes the new hard drive as a DVD drive
have you partitioned and formated it ? unless you do that to the drive it will not show up with a drive letter in windows. go into control panel, administrive tools, computer management, disk management - there you should see all your drives and you can partiton, format, assign or reassign drive letters to them. hope this solves your problem.
Apr 18, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Apr 04, 2008 | Computers & Internet
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Intel Server Board SE7505VB2 Motherboard Logo
381 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
