Question about Brother DCP117 All-In-One InkJet Printer
How to replace ink absorber pads in brother dcp 117c
  • Anonymous Mar 18, 2014
    troubleshooting, the ink absorber is full DCP-J725DW
What to do if it always appear in the monitor of the printer that ink absorber is near full?
Not only the absorber must be cleaned, also the counter must be reset. I know there is a program for older Epson printers to reset the counter. I found a reset procedure for a brother printer here:
How to Reset Purge Counter on Brother DCP J315W Printer
Perhaps you can fine one for yours?
Feb 21, 2015 | Brother DCP-J125
Hi, i am from India and have a Brother DCP-165C Printer. Now i am facing problem with my Brother DCP-165C Printer. It is showing " Machine Error 46" What is this problem & how can i get a solution. ...
Machine Error 46 indicates that the ink absorber pad is full and needs replacing. You will need an engineer to replace this.
If your machine is out of warranty, please contact Brother Customer Service:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
M-F, 9:00am to 8:00pm Eastern Time
Jan 19, 2014 | Brother DCP-330C All-In-One InkJet Printer
My brother dcp-330c was unable to clean 46
If you are giving the error as 46 see below the error chart fix. I hope this gets you going and thanks for using Fixya. The number is 800-284-4329 What the error is saying is shown below. I copy and pasted so let me know if it doesn't show up for you and thanks for using FixYa.
Error 46 Ink absorber pad is full...replace it contact brother customer service.
46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us".
Jan 26, 2011 | Brother Office Equipment & Supplies
How do I replace the ink absorber pad, where in the printer is it.
Hi There
To get at the ink pads all the printer goto be taken apart it a big job, you cant miss the ink pads when you open the printer apart it one big mess of ink there.
All the best Pineworks
May 02, 2010 | Brother DCP-135C Flatbed Digital MFC...
Brother dcp-150c Clean Unable 46
If you actually changed the flushing box, you should know how to go to the maintenance mode and reset the waste ink counter. Info. that is only available to Brother techs.
Jul 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother dcp117c
Hi Jay,
let me guess, your dcp is about 2,5 years old, right? You have used generic ink carts and very often used the manual cleaning, right?
You need a new waist ink absorber,, which can be purchased at any service partner near your home (see brother homepage of your country). When done so you have to open the dcp and to replace the box. At last you have to reset the eeprom:
press menu then start bk-copy then fourtimes arrow-up (quickly after another). machine switches to maintnenace mode. press by help of the arrow-up and after each digit the set key: 8  0 (zero).
Press start bk copy til PURGE64xx appears. Press 2 7 8 3 (Arrow up and set key) and then STOP.
To leave maintnenace press 9 then 9. After machine comes up in a normal stae the error message is disappeared.
Please DO replace the box first before doing the reset. Otherwise you will seriously damage the dcp!
Mar 12, 2008 | Office Equipment & Supplies
Brother DCP117 All-In-One InkJet Printer Logo
1,734 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
