Question about Gateway FPD1775W Monitor
My monitor does not display any color other than blue.
My Gateway FPD1775W TFT LCD Monitor stopped displaying any color other than blue a week ago. No matter what I do, it doesn't change. I have switched out my monitor cord and it did nothing.
    Sniper:
  • 58 Answers
Check monitor button to select proper colours or reset it to factory settings
Posted on Sep 08, 2009
  • aschauhan11
    aschauhan11 Sep 08, 2009
  • aschauhan11
I was given an ilive dvd player boom box, model IBPD882B and the display screen doesn't work. Can I get another screen for player?
yes, but check connections
7inch TFT LCD Display HSD070I651 480×234 Resolution 7"Analog ...
https://www.ebay.com > ... > LEDs, LCDs & Display Modules > LCD Display Modules
7" HSD070I651 480X234 LCD Screen Signal Interface 26 pins TFT Specific Analog RGB, FPC. Resolution 480 ( RGB)×234. Viewing Angle 60/60/40/60 (Typ.). (CR?10) [Left / Right / Up / Down]. Display Mode TN, Normally White, Transmissive. ' eBay!
7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button ...
https://www.amazon.co.uk/234-Resolution-Button-Monitor-420-TV.../B013FVEJP2 7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button Leg Monitor with 420 TV Lines Night Vision Camera: Amazon.co.uk: Car & Motorbike.
7-inch TFT LCD Module with 480 x 234 (RGB) Resolution, Available in ...
www.globalsources.com > All Categories > Electronic Components Number of the colors: 65KModule dimensions: 164.9 x 100.0 x 5.5mmVA size: 7 inchesAA size: 154.08 x 86.58mmResolution: 480 x 234 (RGB)LCD type: TFT and transmissiveViewing direction: 12:00IC: HX8227-A01 and HX8655-ABacklight: CCFL backlightOperating temperature: -10 to 60 degrees CStorage temperature: ...
Feb 06, 2018 | iLive Televison & Video
Gateway fpd1760 tft lcd color monitor i not warking
- isolate the problem first by checking all the cables for any bent pins and loose wire/ connections - unplug the lcd monitor and try to get a spare computer to check if its your computer's video card or the lcd monitor - if lcd will give display using a different computer it only means there's something wrong in the computer's video card - if lcd will not give display using a different computer it only means lcd had gone bad and needs to be replaced.
thanks.
Jan 03, 2011 | Gateway FPD1760 Monitor
Colors are off on various web pages--red links are blue--pictures and game screens are okay though --Windows XP Pro--TFT LCD Color Computer Display
install the drivers of display new if persist then insert AGP card in AGP slot of grade 8X because that is not problem inbuilt display card does not support games and movie
Mar 05, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
My monitor has a variety of colors going down the left side of the screen and across the top of the screen
increase colour quality 24 or 32 bit from display properties, if there are no options than u have to install display driver.
Aug 02, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
My monitor light comes on but there is no signal.
Isolate the problem. Connect the problem monitor into different computer. If the problem monitor worked on another computer, try connecting a CRT monitor to the problem computer. Once the display comes back, change the screen resolution.
Jul 29, 2009 | Gateway FPD1775W Monitor
Wide vertical lines on screen
Hello there!
First things First
1) If you can or have another monitor try and see if the problem persist.
2) RMS the monitor if you keep these problem in these particular monitor.
3) usually these, problems, its cause by a bad capacitor in the monitor motherboard, or resistor.
4) it is best to return the monitor.
Carl
Apr 25, 2017 | Gateway FPD1775W Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Open Questions:
Best Cloud Storage App For Android 2018 All business organizations now a days, look for extensively secured archive data services. It is important to implement automated and easy-to-use online backup services for creating long lasting data storage, since, portable media has become an expensive and outdated method for protecting confidential business and personal data. In order to achieve this aim of automated and easy-to-use server cloud backup solution, ultra-secure, affordable and user-friendly technology is required. Cloud based backup services seem to be an ultimate solution for maintaining data backups without making huge investments. Provide users the Online Cloud Backup convenience of storing data on the cloud, effortlessly without any hassles. The user friendly features of cloud computing network makes lives easier with facilities like 24*7 file restoration and high scalability levels. For maintaining high levels of security, data is encrypted using 256-bit encryption key on server cloud backup solutions. In order to gain additional security, the user can view encrypted files sent through Internet using a secure channel. Along Computer Data Backup with activating local encryption, most of the users has the choice of communicating using backup server with the help of Secure Socket Layer technology. For all your personal and professional data storage needs we at Dataalign provide, easy-to-use, extremely simple to install, highly secure solution which is secured with all Free Cloud Data Backup modern technological features. Dataalign provides low priced yet effective cloud computing services so that you can make maximum business profits. So, for making your lives less complicated and more sorted contact our toll free helpline number 888 784-9316 for any Business Server Data Backup assistance regarding server cloud backup solution.
Jul 16, 2018 | Socket Computers & Internet
See all Gateway FPD1775W Monitor Questions
Gateway FPD1775W Monitor Logo
306 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
