Question about Asko D1796FI Built-in Dishwasher
My Asko D1976 dishwasher is not cleaning well, and
My Asko D1796 dishwasher is not cleaning well, and there are food particles and pooled water in the bottom. How do I clean this and/or fix the problem?
  • 725 Answers
I would check you drain it must be clear and it must also raise above the bottom of the sink to keep water from the sink going back into the dishwasher..
Hope it helps if Not let me know more about you problem..I can help
Posted on Sep 26, 2009
Asko dishwasher D5233 -- food particles left on glasses after wash
Your best bet is to clean the wash arms and drain filters at the base of the dishwasher. If this makes no difference then it is likely the diverter valve is not functioning and causes the drain water to mix with wash/ rinse water.
http://www.repairclinic.com/PartDetail/Diverter-valve/8801389/1489040
See manual
http://www.ajmadison.com/ajmadison/itemdocs/Asko_5233_ADA.pdf
Apr 20, 2014 | Asko Dishwashers
D1976 machine won't do anything but pump out.
The flood switch must have tripped. This is likely to happen if there is a water leakage.
If you can pull the dishwasher out (after turning off the power and water connections) and tilt it on one side. Wait a little (to let the switch dry up) and then turn it on.
Hope this helps.
Jun 17, 2011 | Asko D1976 Built-in Dishwasher
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
Asko D1796 control panel will not reset....it is showing 5 on it
shut power off at breaker, look under washer there is a pan, if any water is in that pan, there is your problem, remove the water with a towel, plug washer back in
Oct 31, 2010 | Asko D1796FI Built-in Dishwasher
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Sep 18, 2010 | Asko D1976 Built-in Dishwasher
My Asko D1976 dishwasher is not cleaning well, andmy Asko D1796 dishwasher is not cleaning well, and there are food particles and pooled water in the bottom. How do I clean this and/or fix the problem?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
uior24567
Sep 08, 2009 | Asko D1796FI Built-in Dishwasher
F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Apr 22, 2007 | Asko D1976 Built-in Dishwasher
Asko D1796FI Built-in Dishwasher Logo
535 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
